04-06-07, 08:47
#121 (permalink)
| | King of Gloss!
rydawg is offline
Join Date: Jul 2006 Location: MA / NH Posts: 2,937 | Re: I found my favorite light compound/polish! OTC too I buy them at a local body shop supply store.
Raising The Gloss Bar
One Car At a Time!
04-07-07, 02:42
#122 (permalink)
DragRace is offline
Join Date: Mar 2007 Posts: 6 | Re: I found my favorite light compound/polish! OTC too Quote: |
Originally Posted by rydawg Are you using a PC? What color?
If so a simple process would be
Wash
clay
ultra cutting creme light w/pc on yellow LC pad or white pad depending on paint
presta swirl remover, zpc or 106ff on a white lc pad
wax or sealant | Ok,bare with me here,as I'm new here
What is a PC? I have always used pads to apply paint cleaners and waxes.
Paint is a dark green colored Ford Explorer.
04-07-07, 06:41
#123 (permalink)
| | Hayabusa
atticdog is offline
Join Date: Apr 2005 Location: Massachusetts Posts: 1,322 | Re: I found my favorite light compound/polish! OTC too
08 Scion XB Gold Rush
03 Toyota Echo 40+ MPG
01 Suzuki Hayabusa GSX1300R
04-09-07, 08:21
#124 (permalink)
| | member from the old board
tom p. is offline
Join Date: Mar 2001 Location: boston Posts: 3,296 | Re: I found my favorite light compound/polish! OTC too I checked with my local body shop supply store and they need $27 for the blue Presta pad, $26 for the green and $22 for the adapter. I'm not all that keen on spending $80+ on something I may use once or twice.
Does Edge = Presta or vice versa?
It sounds like the industry has moved to this quik disconnect system for pad mounting. I've got a boatload of foam pads and just bought some of the Propel. I'm really not keen on starting in with a new "system". I don't use the PC and Makita enough to justify it and have little need for paint "correction".
The store said they have the old style single sided wool pads by 3M attached by the bolt thru center method. They're around $10. I've got a couple of NOS Schlegel pads as well.
Any thoughts? Thx. | |
04-09-07, 01:32
#125 (permalink)
| | Prep Prep Prep!
SilvaBimma is offline
Join Date: Nov 2003 Location: Vancouver BC/NC Posts: 1,151 | Re: I found my favorite light compound/polish! OTC too Quote: |
Originally Posted by tom p. I checked with my local body shop supply store and they need $27 for the blue Presta pad, $26 for the green and $22 for the adapter. I'm not all that keen on spending $80+ on something I may use once or twice.
Any thoughts? Thx. | Highly doubted considering Edge has a patent pending for the Adapter (I believe, need to check). Also note there aren't many actual pad manufacturers that take the foam and apply it to backing plates or velcro.
04-09-07, 01:46
#126 (permalink)
wannafbody is offline
Join Date: Feb 2005 Posts: 5,636 | Re: I found my favorite light compound/polish! OTC too Quote: |
Any thoughts? Thx. | Stick with Velcro backed pads- you can find the Makita wool pad with velcro backing at some Lowe's stores.
2000 WS6 TA NBM
04-09-07, 03:13
#127 (permalink)
| | King of Gloss!
rydawg is offline
Join Date: Jul 2006 Location: MA / NH Posts: 2,937 | Re: I found my favorite light compound/polish! OTC too TOM P.
Edge makes the pads and buffing pad system for Presta. If your just gonna do a job once then buy the Schlegal wool velcro pads. They are excellent pads and they should be around $10. Then you can finish with the foams you have.
One Car At a Time!
04-09-07, 04:18
#128 (permalink)
tom p. is offline
Join Date: Mar 2001 Location: boston Posts: 3,296 | Re: I found my favorite light compound/polish! OTC too OK, thanks, guys. I did a little more telephoning this afternoon and found a more reasonable solution. My local guy (Milford) can get the all the pcs. for around $55, which I can live with. If this strategy is highly successful, I'll use the wool pads + #1500 polish more in the future when I typically woulnd't reach for something like that. It could turn out to be time-saver
I assume I can use the adapter with the small Edge foam pads, etc., right?
Thx. | |
04-09-07, 04:38
#129 (permalink)
| | King of Gloss!
rydawg is offline
Join Date: Jul 2006 Location: MA / NH Posts: 2,937 | Re: I found my favorite light compound/polish! OTC too Quote: |
Originally Posted by tom p. OK, thanks, guys. I did a little more telephoning this afternoon and found a more reasonable solution. My local guy (Milford) can get the all the pcs. for around $55, which I can live with. If this strategy is highly successful, I'll use the wool pads + #1500 polish more in the future when I typically woulnd't reach for something like that. It could turn out to be time-saver
Thx. | You can use the small edge pads on the rotory too. System is pretty cool but not cheap. I also use the regular pads too. I have tons of backing plates and have them attached to different pads and can change real fast with the rotory button and a twist.
I wish these items were much cheaper.
One Car At a Time!
04-11-07, 05:01
#130 (permalink)
tom p. is offline
Join Date: Mar 2001 Location: boston Posts: 3,296 | Re: I found my favorite light compound/polish! OTC too | |
04-11-07, 05:46
#131 (permalink)
| | King of Gloss!
rydawg is offline
Join Date: Jul 2006 Location: MA / NH Posts: 2,937 | Re: I found my favorite light compound/polish! OTC too Tom, Is that the stuff you just got?
One Car At a Time!
04-11-07, 06:01
#132 (permalink)
tom p. is offline
Join Date: Mar 2001 Location: boston Posts: 3,296 | Re: I found my favorite light compound/polish! OTC too Yes, I picked up the pads this afternoon and the Z*PC arrived, too. Still waiting for the Presta polishes (3) to arrive. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 02:33. | | | |
