Old 11-27-06, 09:53   #1 (permalink)
bill57 is offline
bill57 is on a distinguished road
Light cut pad - Heavy cut Polish
If I use Megs #2 with a white pad on my PC, would I get close to the same results as if I used (say) Megs #9 or #82 with an orange pad on my PC?
Old 11-28-06, 09:20   #2 (permalink)
Re: Light cut pad - Heavy cut Polish
Noting that I don't use Meguiar's (abrasive) polishes much these days and I haven't used #2 since it was reformulated...
The combination is only as effective as its most aggressive component and it's only as *mild* as its *least* aggressive component. So you have to match the pad and product up properly for starters no matter what. It's generally best to pick the proper product for the type of work (e.g., #2 for real correction, #9/#82 for very gentle final polishing) and then use the mildest pad that'll get the job done.
With the exception of really aggressive cutting pads, the pad merely allows the product to perform in a certain way. Orange pads are right at the edge of contributing cut of their own vs. merely allowing the product to perform so they can be a special case. Sometimes they'll leave a ready-to-wax finish but it's not a sure thing and I always follow orange pad work with something milder (*always*).
I'd *NOT* use #9/#82 with an orange pad, too harsh a pad for those products; it'd simply be a bad match up and could very well lead to slight micromarring. IMO it'd be a case of the product mitigating the effects of the pad rather than the pad enhancing the effects of the product.
A more aggressive product (e.g., #2) on a milder pad can be a great combo; that's the way I tend to match my pad/product. If that doesn't do the job then switch to an orange pad, but #2/polishing pad is a good starting point. Do the correction with #2 using whatever pad you need and then do a quick follow-up (if needed) with the #9/#82.
Once you match the product to the pad in general terms, it's a matter of using the right level of aggressiveness for the job.
Old 11-28-06, 10:30   #3 (permalink)
Heikes's Avatar
Heikes is offline
Heikes is on a distinguished road
^^ very well put. I concur.
Old 11-28-06, 10:50   #4 (permalink)
wannafbody is offline
I'm not sure I totally agree. The orange pads are a special case IMO. They have a pore size similar to a softer polishing pad and the density to fully work and break down abrasives. They are quite versatile. I've used ZPC by orange pad and a RO and it left a LSP ready surface. Maybe a softer pad would have been a slight improvement. With an orange pad I think experimentation is needed.
2000 WS6 TA NBM
Old 11-29-06, 10:06   #5 (permalink)
Originally Posted by wannafbody
The orange pads are a special case IMO....[and] I think experimentation is needed.
Yeah, IMO the orange pads are kinda a wildcard and what happens will depend a lot on the paint (and products) in question. I don't think we're really disagreeing, just bringing up that old YMMV thing I was being *very* general in that last post and just trying to steer bill57 away from the aggressive pad/mild product combo.
Old 11-29-06, 01:19   #6 (permalink)
ZoranC is offline
ZoranC is on a distinguished road
From what Patrick from Excel Detail told me (that white will support heavier / thicker products than gray) and from what I read elsewhere (that gray is not to be used with products that are abrasive) I conclude that one should not match more aggressive product with milder pad if difference between two is above certain "amount".
On the other hand Meguiar's sells just two pads on the gentler side of spectrum (polishing and buffing) and I have seen people use them for everything.
Any comments, please?
Old 11-30-06, 11:45   #7 (permalink)
ZoranC- First, here's a disclaimer: it all depends on the paint and the products in question, gotta watch the generalizations and people have different standards of what's OK too. That having been said...
I seem to get by with far fewer types of pads than many people. For a *long* time I just used one (green) on the Cyclo and one (Griot's orange) on the PC. For ages the green was the only one they even sold for the Cyclo. I've added a bunch of different pads since those days, but it's not like I really *need* a really wide range of pads with the products/paint I'm dealing with.
Does the pad let the product do its work the way the user wants? Does the pad have any functional cut of its own (on the paint in question)? To me those two Qs are all that matters and sometimes the (truly, real-world-functional) answer to those Qs is pretty simple.
Old 11-30-06, 12:22   #8 (permalink)
ZoranC is offline
Originally Posted by Accumulator
... gotta watch the generalizations and people have different standards of what's OK too. That having been said...
Got it! Thank you!
Old 11-30-06, 06:29   #9 (permalink)
Adamah's Avatar
Adamah is offline
Adamah is on a distinguished road
Send a message via ICQ to Adamah
I disagree there. Its still only as mild as the most aggressive component. IE: AIO on a wool cutting pad.
Anyone got a '96 Impala SS for sale?
Old 12-01-06, 07:40   #10 (permalink)
bill57 is offline
Thanks for the feedback, guys.
So, it's OK to use a mild pad with an aggressive polish, but not the reverse?
Old 12-01-06, 12:24   #11 (permalink)
ZoranC is offline
I know next to nothing, so my answer will be probably worthless and incorrect, but my guess will be that that would depend on how much pad itself contributes to the action. In that case answer would depend on which pad you have in mind. I heard that cutting pads have a contribution of their own, which is logical to me. But what about other, less agrressive pads? How much real world contribution there is from orange, green, yellow, white, if any at all?
Old 12-03-06, 09:29   #12 (permalink)
You're right, it all hinges on the *most* aggressive component; I really botched that one up Thanks for catching that and posting the correction.
ZoranC- As mentioned, the orange light cut pads are a somewhat special case; sometimes they contribute cut and other times they don't. IMO it depends on the paint, and that goes for many "polishing" pads too. The Cyclo green pad has functional cut on some paints but not on others.
*Generally*, and just *in my experience* most polishing pads like the Meg's 8006, the LC white, and the Griot's orange do *not* have any functional cut of their own, they just let the product work. I can't remember using *any* finishing pad that ever had any cut of its own.
Detailing Car Trim DavidB Guide to Detailing 0 11-10-06 02:12
optimum polish with wool pad opass Machine Polishing 14 11-14-05 06:50
Lots of questions about Pads and backing plates..... AlexRuiz Car Detailing 11 11-05-04 04:06
Has anyone used Rain-X polish on a foam pad with a drill? joed1228 Car Detailing 0 05-02-03 10:27
