Old 10-27-06, 09:18   #25 (permalink)
Sir-Wax-A-Lot
01bluecls's Avatar
01bluecls is offline
Originally Posted by lecchilo
i think i'm going with that also
have to save up though... i'm broke
Yea they are certainly not cheap. But if you are doing paid details, its good idea to have especially when doing paint corrections.
Refined Detailing
Chris - Sole Proprietor
Old 10-30-06, 06:50   #26 (permalink)
Sir-Wax-A-Lot
01bluecls's Avatar
Bumping this thread...need some more info about paint. I have received my paint meter but I would like to know a little more about the thickness of paints as a baseline when I do readings...
On a single stage finish what are typical readings of overall thickness? How much of the overall reading is broken down into the thickness of the primer, base coat top coat?
All the above for clearcoated systems as well?
Any help would be appreciated.
Refined Detailing
Old 10-30-06, 08:40   #27 (permalink)
Paint Correction Expert
tdekany's Avatar
tdekany is offline
See if this helps a little bit.
http://www.defelsko.com/applications...-detailing.htm
Old 10-30-06, 09:30   #28 (permalink)
Sir-Wax-A-Lot
01bluecls's Avatar
Thanks Thomas.
I guess the specific info I am wanting isnt available anywhere really.
Good bits of info found on your link:
"Most factory paint jobs range from 3.5 to 5.5 mils (87 to 137 microns). Thinner readings indicate that the clear coat is almost entirely removed or in the case of single-stage systems that the primer is about to show through."
"Because of the potential for removing the majority of the UV blockers, most auto manufacturers recommend that a maximum of 0.3 mils (8 microns) clear coat be removed as prevention from UV damage to underlying paint layers."
Problem is for example, if I detail my car. Paint reads 135 microns on the hood, my car is 5 years old now, how much of the original measurement is gone. (When it came out of the factory what is the measurement?) How much of the 135 microns is actually clear coat and how much of that is the in microns still has UV inhibitors?
These are the type of questions Im referring to. It seems that the paint gauge is still a good idea/investment but without true baselines its hard to reference actual numbers to compare and be useful to its fullest potential. I did a search for Paint readings measurements on the internet and pulled pretty much useless info. I wish there was a chart that manufactures would release to show these numbers.
Refined Detailing
Old 10-31-06, 12:00   #29 (permalink)
StumpyDetailing is offline
It is good to measure how much you are removing when you do it yourself. Before, after, so you know if you're removing much or none at all. I would guess the PC would remove nearly nothing.
However, I thought I've seen a paint guage that measures up to 4 different materials above the metal, IE, primer, paint, clear.... Just pray there's no bondo!
Old 10-31-06, 03:58   #30 (permalink)
tdekany's Avatar
tdekany is offline
Originally Posted by 01bluecls
Thanks Thomas.
I know what you mean - the 944 read from 376 to 703 or so.
Old 04-08-07, 04:31   #31 (permalink)
///Member
lecchilo's Avatar
lecchilo is offline
Contact: Send a message via AIM to lecchilo
Re: Paint Meter/Thickness Gauges!
i know this thread is old, but I'm going to be buying this very soon, and was wondering how it works bluecsl??
the link above, the one which you say you got it from, doesn't work... their website works fine, but when I click on the paint gauge, there's some sort of error... is it just my comp ?
anyway, let me know how the PTG works
Old 04-08-07, 04:33   #32 (permalink)
///Member
lecchilo's Avatar
lecchilo is offline
oh and I found it here...
Coating Thickness Gages
is that it? seems like a great price compared to what you paid
Old 04-08-07, 07:34   #33 (permalink)
MoPe's Avatar
MoPe is offline
That's the one I found as well.
And I have the same question as 01bluecls... When working on a older vehicle, how do you know how much of the original clear coat has been removed?
And since the above link stated "most" cars have between 3.5 and 5.5. Are there new vehicles out there with more or less? For example I detail a brand new Mercedes Benz, and the reading comes out to 5.8; do I just assume there hasn't been repaint, and treat it as I normally would?
Is this where you would make an assumption? I'm pretty new to paint reading gauges, and I'd like to learn more.
Old 04-08-07, 08:20   #34 (permalink)
tdekany's Avatar
tdekany is offline
for about $3000 you will get a gauge that gives readings up to 3 layers.
That is the only way to know for sure how much clear is left, but it doesn't mean that the gauge we use is useless.
Aston Martins have 11 layers of paint including 2 clear coats. So the reading would be about 190 microns.
Old 04-08-07, 08:30   #35 (permalink)
MoPe's Avatar
MoPe is offline
Right, I understand that, and at this point $3,000 isn't going to happen. I would however like to purchase one of these in the future. What's the name of the product?
Old 04-08-07, 08:46   #36 (permalink)
tdekany's Avatar
tdekany is offline
Car Detailing Training - auto detailing, car detailing
that is the gauge I use and I think Chris uses that one as well. Now I am going to detail so no more from me until tonight.
