I initially posted this on a different forum, but thought I'd share here, as the results were pretty impressive. Hope this helps anyone with hard water decide whether a filtration system is worth the money...
I received the Deluxe Filter System today. The water at my house is very hard, so I thought I'd give this system a shot.
Upon receipt, I checked to make sure everything was there (it was) and proceeded to hook it up.
Installation was a breeze. I just chose a place to mount the canisters, screwed the mounts in and hooked everything up. Only took about 15 minutes.
Next I washed my car with a foam gun using
Meg's GC. Instantly I noticed significantly more suds. So much so I decided to do a comparison.
Here are some images for comparison. Pretty amazing...
Without filter using the foam gun...
With filter using the foam gun...
And some more, after applying with the foam gun.
Without filter...
With filter...
As you can see, the suds are significantly denser when using the filter. Upon drying, the water felt much softer as well.
I don't have a water tester to scientifically compare the two, but going by my completely non-scientific impressions, the system is very impressive and a nice addition to my detailing supplies.
Thumbs up!
