Old 07-07-06, 12:52   #1 (permalink)
Lounging Sound Radio DJ
blackf0rk's Avatar
blackf0rk is offline
blackf0rk is an unknown quantity at this point
Applying Klasse Sealant Glaze (SG)
Directions say I only need a capful per car (2oz), and to apply with cotton cloth. Does anyone have better suggestions for applying such a little amount to a large car?
2003 4.6L V8 Black Supercharged Mercury Marauder
386RWHP 426RWTQ
LOUNGING SOUND - Ambient, Chillout, Lounge, Psytrance, Goa & More
Old 07-07-06, 01:08   #2 (permalink)
turbos = life
autobahn is offline
autobahn is on a distinguished road
Send a message via AIM to autobahn
what I do is for each panel use a dime to a nickel size drop of sg and quickly rub down the panel so you cover the whole panel with a thin coat of SG before it dries. you have to keep an eye on your paint so you apply the SG evenly and don't miss an area.
Old 07-07-06, 01:21   #3 (permalink)
shortspark
shortspark is offline
shortspark is on a distinguished road
What I do is use an applicator squirted a little (just to get it damp, not wet) with a 3 part water to 1 part SG solution. Put the solution in a mister bottle and squirt when needed to keep the pad barely moist or to spray on a high spot or hazed over area. Keep what is left over and use it as a QD to add shine and gloss after a wash. It does not clean well like, for instance, Poorboys SW but it is a super topper for your SG.
Okay, back to the straight SG question. You should use only about a nickle size dab of SG on the applicator. Work it in the pad if you want to but I just give the applicator one little squeeze and rub it on the section in a straight back and forth motion. Keep doing it and it will be very hard to see. If you see it really well chances are you have used too much and it will "haze". In that case, keep going back and forth with your applicator or mist as mentioned above if really necessary. You will soon learn how much to use and how to apply it so don't fret - many people need a time or two with it.
Another issue with SG is to either follow directions and let it "dry" or use a wowo method. The wowo method is the one I use because it is easier, thats all. People who have used both methods have said there is virtually no difference so the wowo is my preference and the only way I've ever used it. I have also heard it is best applied by hand rather than electric buffer. Be sure to let it cure 12 hours or more between coats (three coats should be more than enough) and don't drive between coats or you'll have to wash the car. Remember, you are dealing with a sealant so it will seal whatever is on your paint.
To freshen things up a bit now and then try the home brew formula above or acrylic/polymer QDs and toppers such as Menzerna HGAS, Wolfgang Spritz and FK425 does pretty well too. Lately, I've been using the newest rage here, Duragloss Aquawax after my washes and my SG lsp looks great! Of course, you can always top SG with a carnuba wax - just never put SG over the wax or you'll have bonding problems. Hope this helps.
Old 07-07-06, 01:44   #4 (permalink)
blackf0rk's Avatar
Thanks for all your help!
386RWHP 426RWTQ
Old 07-07-06, 03:16   #5 (permalink)
blackf0rk's Avatar
Originally Posted by VaSuperShine
ive been using it in a spray bottle and rubbing back and forth up and down with slightly damp mf applicator.
This makes LOTS of sense to me...at least from an even coverage point of view. But I don't know how you can limit yourself to 2oz with this method. Do you?
386RWHP 426RWTQ
Old 07-07-06, 03:25   #6 (permalink)
[]D[][]\/[][]D
truzoom's Avatar
truzoom is offline
truzoom is on a distinguished road
Such a fixed amount seems like a mistake on their part. Not all cars have the same paint area!
I think the main idea is to use as little as possible but still make sure you get it on there.
Old 07-07-06, 05:55   #7 (permalink)
Deviant is offline
Deviant is on a distinguished road
Send a message via AIM to Deviant Send a message via Yahoo to Deviant
That about sums it up. Using a damp mf cloth or applicator will help as well. Applying it dry is a little bit harder.
Old 07-07-06, 07:18   #8 (permalink)
PerfectLap
racingbeat's Avatar
racingbeat is offline
racingbeat is on a distinguished road
I don't want to be wet blanket but I used SG for years some great results but there are products that produce equal results without all these considerations.
EXP from Poorboys ,Carlack, Werkstatt Acrylic Jett produce equal results and there is little risk of streaking or having the product turn to glue on your car if you use too much.
There are no greater rewards in using SG.
BoxsterS:GT3 Recaro Pole Position Seats, GT3 Front bumper, 20 lb. 18"Carrera 5 spokes,Toyo RA-1, Valentine 1!
http://www.cardomain.com/ride/789415
Old 07-07-06, 07:27   #9 (permalink)
drck1000 is offline
drck1000 is on a distinguished road
I've used SG without any problems from the beginning. I wet the applicator with soem QD and allow it to dry for an hour before buffing. I even bought Sonus Acrylic Spritz to aid in the removal, which I've never ended up needing and now just sits in my bin of QD/Sealant sprays (it's on the bench behing HGAS). That said, I've read on here where others have had problems removing AJ! I guess each might have their unique quirks. I have AJ coming and looking forward to trying it out.
However, I have never had any problems using UPP or EXP as racingbeat has noted. I can't really comment on durability as I use different post wash sealant sprays on each and add other variables like topping with carnauba to effective compare them. But those are so easy to use, I would be willing to apply every couple of months on my car. I use products like SG and Collinite on other family vehicles that I don't have time to reapply sealants regularly.
Old 07-07-06, 08:09   #10 (permalink)
PerfectLap
racingbeat's Avatar
Hope you got the Acylic Jett Trigger. I was spraying the hell out of one of my doors just to remind myslef that I could never do that with SG.
I'd like to talk to someone at Klassse and ask them how much business they have given away by simply not offering their product in a sprayable form. Its totally retarded. Offer the product both ways and see what happens.
Old 07-07-06, 08:41   #11 (permalink)
Slickery is offline
Slickery is on a distinguished road
2oz can do a bus, I say use 1/2 once or less for a car. Use a damp applicator and it usually takes more at first but once the applicator is primed you should be putting a couple drops per panel. I use a MF applicator when applying SG.
http://www.bettercarcare.com/son-dwa-2.html
Autopia Rocks
Old 07-07-06, 10:34   #12 (permalink)
StumpyDetailing is offline
StumpyDetailing is on a distinguished road
I used Klasse SG for the first time on a Black '01 Corvette yesterday... HOLY CRAP! I've never seen a panel so reflective! It went on amazingly easily, I put a half-dime drop in the middle of a Meguiars Finishing Pad, and it did the rear 1/4 panel by itself... and amazingly, it buffed off perfectly!
I did have bad experiences with it previously, but they were all due to far too much product!
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/car-detailing-product-discussion/74248-applying-klasse-sealant-glaze-sg.html
Posted By For Type Date
Klasse SG Removal Question... - E46Fanatics This thread Refback 11-13-06 09:02
