Old 06-28-06, 06:57   #1 (permalink)
percynjpn's Avatar
percynjpn is offline
percynjpn is on a distinguished road
Used Zaino Z-2 PRO first time!
Hi folks,
I finally had a chance to use Z-2 PRO for the first time today (sorry, no pics). I applied it in conjunction with ZFX, after polishing my '92 Champagne Gold Metallic Silvia "K's" with Optimum Polish by Cyclo with Cyclo white pads.
Some thoughts:
1) Don't care for the smell too much.
2) A bit difficult to spread (kind of "thick"), compared to my other favorite sealants: 1Z Glanz Wax (easiest application in the world!) and UPP (easiest to remove IME).
3) I found it difficult to remove. The temp was about 30C with 60% humidity. I waited about thirty minutes before removal. It may have been the humidity, but after that I used the last tiny remainder for a second application on the hood, then came back about two hours later - same result. I used about 2/3 of an ounce on the whole vehicle (and since there was extra left over, I also applied it to the wheels, too). In short, it was applied VERY thin.
4) Looks: Excellent! My car is a very pale gold; it gives better "gloss" than (my other favorites for this color, UPP and S100). It shines wonderfully, but it doesn't provide what I'd call "deep luster" - a rich, deep - something . That doesn't mean it doesn't look good - just different from what I'm used to. I don't agree with the assessment that it makes the paint look like it's "wrapped in plastic". It really looks great, I just can't describe it well. Overall, I find the look striking and have found a new favorite. I have a feeling its look on black or red will make me more biased as to which product should be used on those particular colors, but you've got a new Zaino fan here!
Old 06-28-06, 07:01   #2 (permalink)
Sooper Genyus
ZaneO's Avatar
ZaneO is offline
ZaneO is on a distinguished road
Good report.
Couple of tips:
Spritzing your applicator with distilled water or QD makes application really easy.
2/3 oz. should have been good for *at least* 2 full coats on the vehicle. You should barely be able to see it going on - this makes application and removal nearly effortless (also reduces drying time).
A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty.
- Winston Churchill
Old 06-28-06, 07:12   #3 (permalink)
percynjpn's Avatar
Originally Posted by ZaneO
Good report.
Couple of tips:
I did actually spritz the (foam) app with distilled water; even so, it was more difficult to spread than other products I've used. For removal, maybe I just used too much product, but I think the "thickness" of it made it difficult to spread easilly. I think next time I'll try to apply it with a cotton or MF applicator, which may make it easier to apply.
Old 06-28-06, 07:29   #4 (permalink)
"That ball wasn't low"
blkZ28Conv's Avatar
blkZ28Conv is offline
I personally can not spread Z very well using a sponge-type applicator. I am sure you will be surprise how well cotton (my first choice) or MF pads works without increasing amount used.
As the saying goes...if you think you applied a thin coat you still applied tooo much.
Nice, fair and objective review. Well written.
Z looks great on Red (Torch). Some will
Zaino beta tester
Old 06-28-06, 08:00   #5 (permalink)
percynjpn's Avatar
Thanks for the advice; after the next wash, I'll apply the next coat by cotton app.!
Todd
Old 06-28-06, 08:08   #6 (permalink)
Time's a-wastin',speedy!
TortoiseAWD's Avatar
TortoiseAWD is offline
percynjpn,
If you have a PC, you might consider giving machine application a try. I also think Z2Pro doesn't spread quite as well as older versions, and I've had better luck laying down thin/easy-to-remove layers with a PC and Sonus SFX-3 4" finishing pad.
Tort
Has the Large Hadron Collider destroyed the earth yet?
F5 frequently, or set up an RSS feed for most recent info . . .
Old 06-28-06, 08:23   #7 (permalink)
percynjpn's Avatar
Originally Posted by TortoiseAWD
percynjpn,
Tort
I do have a DA machine (with two unused LC black pads); these days I rarely use it. Thanks for the advice - I may have to give that a try!
Todd
Old 06-28-06, 09:26   #8 (permalink)
wannafbody is offline
Z2pro looks very good on goldish mettallics
2000 WS6 TA NBM
Old 06-28-06, 09:55   #9 (permalink)
jmsc is offline
jmsc is an unknown quantity at this point
Post Similar To My Exp...
1. I also found Z-2P a little harder to apply than say its counterpart Z-5P. But both came off easy. Both were used with Z-FX.
2. What sized car did you do this to? 2/3 oz may be too much. I used 1/3 then 1/4 then 1/5 as I layered on a 06 Civic.
3. I used a mf appl using pea sized drops (yes, pea sized not dime or nickel sized) using spritz's of distilled water and/or Z-6. Very easy on. Very easy off. With cotton or mf the drop spot stays moist throughout the procedure which helps in the thin application. I used different mf towels (Meg Ultimate, Meg Supreme, Magic Towel, Waynestowel HP & UP) to remove the Zaino. All worked very well for me. Some day I will actually try my Charisma 100% USA cotton towels to remove Zaino.
Old 06-28-06, 10:17   #10 (permalink)
buzzb is offline
buzzb is on a distinguished road
Post some pics if you can percynjpn!
I've found an initial Z6 wipe down and using a microfiber applicator helps me keep the layers thin, thin, thin. A Z6 spritz on the applicator (just a light mist- do not saturate) can help also. Once you start playing around with Zaino you'll find what works the best for you. Hope this helps!
Old 06-28-06, 10:29   #11 (permalink)
Super Enthusiast
SilverLexus's Avatar
SilverLexus is offline
SilverLexus is on a distinguished road
Todd,
My favorite applicator for Z-2 is the PakShak ultrafine app. Really allows it to spread thin in my opinion. I also prefer hand over PC applications. Maybe a preference thing..
~Ferdinand Porsche
Old 06-28-06, 11:07   #12 (permalink)
gben is offline
gben is on a distinguished road
Talking
I recently purchased some z5 pro, z2 pro and used them both with zfx and had no trouble at all applying or removing. ( used both the terry cloth zaino applicator and a store bought mf applicator) Made my yellow vette look better than anything I've put on it so far. Not to say I'm going to stop trying new products on it.
