First off, does anyone scroll down on the site and look at the special edtion versions?
I was curious if anyone has experience with the other versions?
Anyone that has used Prime, do you see advantages to the other versions?
I'm debating on trying the Prime "Acrylic" version, any thoughts?
Thanks Guys/Gals,
Kyle
PRIME: Acrylic
Description: While the standard Prime is wonderfully balanced between all of its functional requirements, we wanted to push the formula further toward the acrylic sealant aspect. Prime: Acrylic maximizes the content of acrylic polymers for improved durabiity while maintaining the ease-of-use that Prime is known for. This formula is tailored for the detailer using Prime as a stand-alone,
all-in-one cleaner/wax rather than as a basecoat for further layers. (Although even as a basecoat, a little extra durability never hurts!) This characteristic is particularly good for areas like engine bays and door jambs where a multi-step process is impractical but where durable protection is important.
PRIME: Carnauba
Description: Prime has always excelled as a preparatory base layer for high-grade carnauba waxes, like our own Carnauba Jett. Now, with Prime: Carnauba, we have a product tailored to this function. The highest grade Brazilian prime #1 yellow carnauba has been carefully integrated into the balanced Prime formulation for a final product that is one step closer to a finishing wax. In fact, the carnauba content of this formula is higher than in many commercial waxes! Yet, the same qualities that have made Prime such a hit have been maintained.
Even when topped by an acrylic or polymer sealant, the carnauba in the base coat can add a bit of warmth, a bit of depth, and a bit of hiding power to the finish.
Note: due to the natural characteristics of carnauba wax, this product is best buffed off after each panel rather than waiting the full 30 minutes as with Prime itself.
PRIME: Strong
Description: We think of this formula as a 120% version of Prime! It employs both more acrylic polymers for better durability and protection and also an incrementally stronger polishing agent to address more paint imperfections. This formula takes Prime a step toward a finishing polish and can eliminate the need for a separate finishing polish in many instances. Prime: Strong can address light marring and swirling more effectively than Prime, yet the polishing agents--though stronger--are still gentle enough for regular use. It makes a beautiful, easy hand polish for those without machine polishers, and it works quite well as a chrome polish and sealant.
