to try out the new tools and here are my findings.
First, the
BIG BLUE TOWEL:
The towel comes wrapped nicely rolled up and secured with a paper band with the
Pinnacle brand name. The only thing that concerned me was that the band was stapled together and if one was not careful, you may cause a snag.
The towel is large, by my standards, approximately 2 by 3 feet. Plenty of drying power. I did not wash the towel prior to use (I know, I can hear your moans!) . After washing my car, it's my normal practice to drench the car with a flat stream of water (without the nozzle) to get some sheeting action going and then move the car into the garage. I folded the towel into quarters (as suggested in a previous post) and began wiping, starting with the roof.
The first thing that I noticed was the the towel has very little drag compared to an Absorber. About the same when using a Magic Towel (from CMA). With the towel completely dry, it quickly picks up almost all of the standing water. After getting half the roof, I flipped over the towel to give it a final dry. By the time that I had completed the roof, rear window, trunk lid, and front window, the towel was pretty heavy with water.
I attempted to wring out the towel, but could not get any water to come out (the arthritic elbow strikes again). The towel weighed approximately 2 lbs at this point, so I figure that there was about a pint of water trapped in the towel.
As I continued on to the hood and front valance, there was more water residue left behind, but the droplets were small. Since today was fairly humid and about 80 degrees, I was impressed that the droplets evaporated fairly qickly and left no streaking.
The towel was leaving a lot of water at this point and I really only had door jambs, under the hood and the trunk area left to do (always a pain!!) so I switched to Viper Detailing Cloths for these areas (plus they get pretty grungy sometimes).
All in all, I am pleased with the towel and think that it's a more than fair value for the price. I will probably purchase a second one on my next order (take advantage of the Magic Towel discount and try the other new ones).
Next, the
Eimann Fabrik Carpet & Upholstery Cleaner:
I had several spots to try this on, but only 1 was on actual upholstery, the other 2 were on a door panel and the lower dash.
The cleaner comes in a typical CMA bottle with the included sprayer (nice touch compared to Griot's Garage). I used a Viper Detailing Cloth, first on the door panel.
I sprayed several squirts on the towel and rubbed gently with no luck. I used more rapid strokes and a little more pressure. This gave me a rather nice lather and a pleasant scent. I dried with a second towel, but whatever the stain is (kind of like splattered milk), it did not remove it. I was not expecting miracles, as this stain has resisted most everything.
Next, I went to the upholstery stain and sprayed first on the cloth, but found that there was not enough cleaner making it onto the fabric, so I put several shots onto the stain and then rubbed in the direction of the weave. Whatever it was, it seemed to disappear very quickly. By using a dry towel, I rubbed out most of the moisture and I left it to dry. Cool !!
I then used it on some marks left on the lower part of my dash (some people just have to cross their feet
) It was able to clean off the scuff marks with very little effort. I also scrubbed another little spot which was removed easily.
Once again, I was highly impressed with the Eimann Fabrik product. So far I have 3, (EF HI, EF CP, & EF C&UC) and they are batting .100
I'll probably buy the entire EF kit next time, as it seems to be a great value, and if the quality of the other cleaners match what I've used so far, then... YAHOO !!
All together, I'm very pleased with my recent purchases and salute the crew at CMA for some killer products. I look forward to trying some of the other new stuff soon.
Fellow Autopians
please let me know if you have additional questions that I left unanswered.
