Originally posted by joburnet I tried using a 400 Watt Power inverter that I got from sams club and it will run but not very fast. It has just enough power to apply wax. I think that most alternators don't even produce that much power so my conclusion is that it is not possible to power a PC with a power inverter on most cars. If you have a large truck or something like that then it may be different. |
A 400 Watt inverter is not sufficient to power a PC which needs 440 Watts. You can run a much larger inverter with just a stock alternator. So your problem is not the alternator, it is your inverter.
Most stock alternators can produce about 100 amps. It is true that they will not produce this much at idle, and it is also true that some of the power that the alternator produces is required to run the electrical systems and ignition of the vehicle. However there is still plenty of power available to run an inverter which powers a 3.7 amp PC. The only exception to this is if you're trying to run a 500 watt stereo system at max volume, your A/C, your
headlights, etc., all at the same time. In that case you might not have enough power available, but for most instances, you will.
