The only pads that will touch my cars are Edge,
Sonus and
Lake Country pads.
Edge makes some good pads, but their primary market is rotary buffers, not PC's. (They do make PC pads, but they are radically different from their other pads. I don't like the shape of their PC pads.)
That leaves you with Sonus and Lake Country pads. I understand that Sonus pads are good, but I use Lake Country pads that I purchased from
www.properautocare.com.
One thing to be aware of is that Lake Country makes different
LC pads for different retailers. The LC "Constant Pressure" pads that I purchased are only available from
www.properautocare.com. Better than other LC pads? I don't know. Different? Yes.
First I started with the 6" LC pad kit with flexible backing plate. They were nice, but I liked the flexibility that the 7.5" pads offered. I came up to speed with the 6" pads quickly, so I ordered the 7.5" pad kit from Proper Auto Care. Here's the 7.5" pad kit with the 6" flexible backing plate:
http://www.properautocare.com/ad712inhipad.html
The 7.5" pads work well, center easily and have a plastic backing that is completely different from the 6" pads (which have no plastic backing). The velcro sticks so well to the backing plate that, after washing, they can be dried by sticking the pad in a large bucket and turning your PC on. (They're almost dry in 30 seconds or so.)
In addition to the kit, you may want to order order a yellow pad for compounding.
If you feel comfortable with a buffer, you may want to go the with 7.5" pads. If not, try the 6" pads. Here's the 6" pad kit with backing plate:
http://www.properautocare.com/hipadkitwive.html
Two additional points:
First, get a backing plate matched to your pads.
a backing plate came with the PC. That's useful for sanding. Also, I understand that, in combination with the pad that came with the PC, it is useful for buffing out the last step product (LSP) with an MF bonnet. However, do NOT use it with good quality polishing pads.
Regardless of where you get your pads and the brand that you buy, make SURE that you get a good quality backing plate with it that is matched to pads that you buy. Different pads require different backing plates. Even some LC pads need different backing plates.
The 6" flexible backing plate that I bought with the 6" LC pads also fits the my 7.5" LC pads. It works great. After a several hours of use on four cars, the pads and the backing plate are still in perfect condition. No foam tearing. No loose velcro. So...
Strong recommendation - Get a backing plate matched to the pads.
Second, get something to clean the pads. I use "Snappy" from
www.properautocare.com, but there are other choices and other vendors which also may be good (check around).
I hope this helps.
Regards,
Dan.
