Old 07-19-04, 11:04   #1 (permalink)
Director of Training
Mike Phillips's Avatar
Mike Phillips is offline
1975 Corvette Extreme Makeover - The importance of a Paint Cleaner
Tuesday night, starting at 5:00pm, we will be conducting an extreme makeover on this 1975 one-owner Corvette.
This car was brought to the CorvetteForum at Meguiar's! detailing clinic this last Saturday and because of the extreme Dirt in paint condition of the finish, we used it to demonstrate the purpose of a Meguiar's paint cleaner.
You see, over time, without proper maintenance, paint can become dirty, not as in dirt on the car, but as in dirt in the paint, also known by the acronym, DIP. Dirt in paint is also referred to as road stain, or just stained paint. The point is, dirt can build up below the surface of a car's paint in the microscopic surface imperfections, which normal washing will not remove.
When this car pulled in, we inspected it closely to find out that while the owners were washing and waxing the car regularly, the wax they were using did not have any cleaning ability and thus would merely coat over the dirt in the paint, and not remove it.
Also, two portions of the car have been repainted, the front valance, and the rear valance. Extraordinarily enough, the body shop that repainted these portions did not afterwards buff out the rest of the car so that the old, stained and oxidized paint would match the new paint in color and gloss.
Often times, a body shop will buff the entire car out as a courtesy to the customer and so that there isn't such a dramatic difference between new and old paint. Because a lot of times these types of buff-outs are done quickly, the quality of the work and the chemicals used can be questionable. In a way, the owners of this Corvette are lucky that the rest of the panels were not buffed out, as we're going to do it the right way using premium quality products and professional techniques which will takes this Corvettes finish to its maximum potential!
Below are some before pictures. Note the car was washed before it was driven to Saturday's detailing clinic. The dirt, or staining you see in the paint, not on the paint.
[b]Here is a close-up of the finish. The black or grayish looking area is actually dirt that has built-up in the paint.
While the above photo's show some areas where the dirt is concentrated, the entire finish is stained with dirt in paint.
The below picture shows a circular area where we applied some ScratchX, an advanced Meguiar's paint cleaner for use by hand.
Later, towards the end of the class, we polished out one half of the hood using some #83 Dual Action Cleaner Polish on a W-8006 foam polishing pad on Meguiar’s G-100. The results between before and after are dramatic. The results also help to demonstrate the concept of dirt in paint and the importance of choosing the correct product for maintaining your car's finish.
Below you can see the new paint on the front valance, versus the old paint on the hood. Note how the old paint is dull and lifeless with no gloss whereas the new paint is vibrant in color with high gloss.
We will be using and demonstrating a wide variety of products for the extreme makeover of this one-owner 1975 Corvette. If you would like to be a part of the team that performs the dramatic transformation, the come on down to Meguiar’s Garage this coming Tuesday night.
Here's the address,
Meguiar’s address for Mapquest Driving Directions
Meguiar’s Inc
17991 Mitchell South
Irvine, CA 92614
The transformation begins at 5:00pm, see you here!
Here's the thread to follow along for the results...
Mike
mphillips@meguiars.com
Note: The acronym DIP and the term dirt in paint is also used in the refinishing industry to describe dirt and dust that lands in fresh paint and becomes embedded in the top surface as the paint continues to dry. After the paint has dried, professional body shops will remove the dirt specs usually by sanding and buffing.
Mike Phillips
1-800-869-3011 x206
Mike.Phillips@Autogeek.net
"Find something you like and use it often"
Old 07-19-04, 08:35   #2 (permalink)
Doc96 is offline
Great write up, Mike. My son's Civic paint shows similar "DIP" and we have been planning to hit it with the PC and DACP after claying. Won't get your results but we're looking forward to a great improvement.
Doc
Old 07-19-04, 09:51   #3 (permalink)
Doc
Sure you will, just take your time, overlap you pases by 50%, work the product till it has completely broken down but you're still leaving behind a wet film, run the polisher on about the 5.0 setting and apply 4-5 lbs of pressure.
Heck, anyone can do it... I've had kids from 9 to 16 at the Saturday clinic learn how to use the PC and get stellar results.
Here's a tip: Wash the car the night before so you have that out of the way, then get up early with your son and get a early start on it. Purchase some blue painters tape for any plastic trim or hard to detail areas like wiper grills and the such and tape these areas off. Have a good supply of clean, 100% cotton towels and premium microfibers polishing cloths on hand.
Load up a cooler full of cold beverages, some snacks and a radio with the Beach Boys playing and you're guaranteed success!
Mike
Mike Phillips
1-800-869-3011 x206
