Originally posted by srtchad I ask this because I used it the other day by pc and a cutting pad, like the web site says to work it till dry and then wipe off. Well it did wonders for the swirl marks but it left a LOT of hazing behide. I had to use IP and FP to bring back the gloss.
Just wondering if anyone else has used this and got less hazing on the paint??
Thanks,
Chad. |
If this is the Hi-Temp stuff, pink in color.....then your greatest results will come with a rotary and a polishing pad. The rotary, with its combined heat and friction, allow the products cleaners to properly level paint and then polish the paint. If you are only using a PC then, as already noted, go to a softer pad, like LC's black finishing pad.
If you are using a cutting pad with the MC and a PC then long after the MC has done its work you are still abrading the finish with the cutting pad, in other words nothing between the paint and the pad to lubricate it.
Anthony
