Results 1 to 3 of 3
Thread: Clay lube...
  1. #1
    Clay lube...
    pugoman's Avatar
    Join Date
    Jan 2004
    Location
    Wiltshire, UK
    Posts
    820
    I usually use a car shampoo mixture as a lube when claying, but just recently I've received a bottle of QEW from a fellow Autopian and was wondering if anyone uses it as clay lube? Will it do any harm used as a clay lube? If it's OK to use, then what dilution ratio do you guys use?
  2. #2
    6cyl's_of_fury's Avatar
    Join Date
    Oct 2003
    Location
    West Siyeed, Sydney
    Posts
    546
    I have one with car shampoo and one with QEW. I personally use 1/2 to 1 capful per spray bottle. YMMV, just make sure its "slick" enough to lube adequately.
    I have a black product test bed otherwise known as a car
    2003 Ford Falcon BA XR6
  3. #3
    Scott P's Avatar
    Join Date
    May 2002
    Location
    Porter, TX
    Posts
    786
    I've never tried QEW for lube. It sounds like it should work fine.
    Owner - Specialty Motoring Products
    When you stare into the abyss, the abyss stares into you. - Nietzsche
Posting Permissions
  • You may not post replies
  • You may not edit your posts
