I have been told that it is best to remove the old wax/sealent before using a SMR to takle swirls. Instead of using a Paint Cleaner with my PC, I want something like Griots Paint Prep that i can just easily spray on and wipe off to remove the old stuff in minutes. At $15 dollars a bottle for the Griots Paint Prep, I am looking for something alittle more cost effective, so my question is what are my options?
I have read that I can make up a spray bottle of Isoproyl Alcohol/Water and that will
remove wax. What dilution ratio(Product:Water) do I use to remove both wax and sealent by simply just spraying this on and wiping it offthe paint? Also is this a safe product to use on all paints on the entire vehicle like this?
On the
Meguiars site it says that APC+ can be used to remove old wax at a dilution ration of 64:1. Does anyone use this in a spray bottle to remove the old wax and sealent from thier paint and how did it work? Would this be a better choice then Alcohol and be more like the Griots?
Are these two my 2 best options or are there other products or choices out there that I can safely put in a spray bottle to remove old wax and sealent to an entire car? Thanks for all the help
