**I'm reposting this from earlier today. The first thread was lost in the outage. Sorry to those who commented before, nothing I can do to bring your posts back.
Also a special thinks to BW, if he had not saved my post I would have to retype the whole thing! I guess I'll learn my lesson and start saving important tests to MS Word.
Hello my fellow Autopians. Since the release of
NXT to the general public I've been playing around with it, testing all it's aspects. I decided to test
NXT against the two old friends many of use and know well, Zaino Z2 and Klasse SG.
Background: I took a blue sharpie marker and applied 2 lines to the surface of my Maytag dryer. Each product was applied, starting with Klasse SG, then Zaino Z2 and finishing up with
Meguiars NXT. I used brand new yellow foam applicators, a separate one for each product of course. I chose this for 2 reasons. One being that it gives each product an "equal" chance in terms of application. The second is the blue marker would show up very easily against the yellow pad should the product remove any of the marker.
Here is the lineup!! From left to right: Meguairs NXT, Zaino Bros. Z2 and finally Klasse Sealant Glaze.
First up, Klasse!
Klasse Sealant Glaze: To begin, I have my bottle of SG a nice shake and put small drop (a little bigger than the size of a dime) onto the pad and started working it back and fourth in the center of the line. Here's a pic of the application.
I worked the product 5 strokes back and fourth, applying medium pressure. The final result was Klasse SG didn't remove any of the blue sharpie marker and the application pad was spotless with no hint of blue. Here's a pic of the pad and line after application of Klasse SG.
Next up, Zaino Bros Z2!
Zaino Bros. Z2: Once again to begin with Z2 I have the bottle a nice shake, and applied a drop (same size as Klasse SG) to my foam applicator and went to work. I went through the center of the line, working 5 strokes back and fourth with medium pressure as I did with Klasse. A pic of the Z2 application.
After application I examined the pad and lines. Zaino Bros Z2 did not remove any of the marker, and the pad was spotless, and not trace of the blue marker, just like Klasse. Here's a pic of the Zaino pad and lines after application.
Last up,
Meguiars NXT!
Meguiars NXT Tech Wax: As with the other 2 products I started by giving the NXT bottle a nice healthy shake. Once again, I applied a small drop (same size as Klasse SG and Z2) and applied the product to the center of the lines using medium pressure, just like I did with the other 2 products. I used the same 5 strokes back and fourth. A pic of the NXT application.
After application I examined the pad and lines as I did with the previous products. To my disappointment NXT removed the sharpie marker. The center of the lines were totally removed, and the blue marker is clearly seen on the yellow applicator pad. Here's a pic of after the application, the lines and the pad.
Well folks, there you have it. In my testing NXT
DOES demonstrate cleaning ability. I'm not going to get into how much this effects layering, or if it makes this product a "cleaner type" product, that's for you to decide. I'm just the moron that did the testing. Ready for flames!
