Page 1 of 3 123 LastLast
Results 1 to 12 of 27
  1. #1
    Question A2Z may be causing damage??
    Jngrbrdman's Avatar
    Join Date
    Jul 2001
    Location
    ...right behind you!!
    Posts
    6,219
    Blog Entries
    5
    Images
    18
    I didn't want to hijack the other thread so I started a new one. For the record, I haven't been anything less than absolutly pleased with the results of A2Z. I'm just trying to eliminate that as the cause of the damage first before I dig further.
    I'm going to take some pictures to add to this thread later, but I wanted to ask the question first. Has anyone used only A2Z on their wheels long enough to notice if it was causing any long term damage? I've been getting my car in shape for a show this coming weekend for awhile now and I just noticed that the clear coat on the lip of my rims is starting to look a little eaten up by something. I've only had them for a year and I've only used the new forumula (orange bottle) of A2Z on them since I got them. I even used SG on them to help protect. Using A2Z everytime I washed the car (usually once a week) has helped keep the brake dust from collecting in the corners behind the rivets on the wheels, but if it has caused the clear on the lip to peel then I'm going to be pretty ticked.
    I recently got some of Platinum's new wheel gel and will be using that for awhile to see how it works. 2 of my wheels were unfortunatly curbed a few months ago and I'm finally taking them off and putting new ones on. I'll be using this new wheel gel on the wheels now and maybe in a year if I notice that the new ones are peeling then I can just chalk it up to bad craftsmanship. I am very concerned that A2Z may have caused the damage though. I'll get some pictures of the damage tomorrow when I have the two bad wheels taken off. That way I can get some better angles of the wheel to take pictures of.
    Has anyone else noticed that A2Z may be causing some damage?
    "It is the mark of an educated mind to entertain a thought without accepting it." -Aristotle
  2. #2
    Join Date
    Feb 2003
    Posts
    3,932
    If I remember correctly, another member indicated that after a year he was noticing that his driveway was starting to show marks as if it was eaten up.
    I use it on really neglected wheels. I have to assume that weekly uses over time can cause damage. It is rather caustic (sp?)
    Do you need to use it WEEKLY? If you keep them protected with AIO, SG or Zaino, then you shouldn't need the EO all the time.
    I use Wheel Wax and Collinite and only need car wash soap and water that I mixup in a bottle. There is next to no dust build up.
    I know it's expensive, but why not P21s gel on those corners behind the rivets a couple times a month?
    I just think that those weekly uses on aftermarket rims may cause damage. The outer lip of the wheels on ALL of my family's cars (not mine!) are missing the coating and are white in color. Yet the rest of the wheel is fine. Sounds like you are at the begining stages of going down that path. I'd switch your routine and save the EO for nasty jobs.
    Just my $.02
  3. #3
    Jngrbrdman's Avatar
    Join Date
    Jul 2001
    Location
    Posts
    6,219
    Blog Entries
    5
    Images
    18
    Yeah, that is what I'm thinking. I don't spray it directly on the lip when I clean so I'll have to analyze the damage areas and see if maybe they are run off from the rest of the wheel or something.
    The new Platinum gel seems to be similar to the P21S gel. I'll have to run them side by side and see which works better. I've never used gel much on my wheels. I always thought that A2Z was as good as it could get. Time to dust of the P21S and see how it does. These wheels are hard enough to find without needing to replace them every year.
  4. #4
    Join Date
    Feb 2003
    Posts
    3,932
    AH! Found it! From Bjwebster:
    What Scares Me About Using It To Often On My Nice Summer Wheels, Is That After Using A2Z 10 or so Times, My Driveway Had 4 Spots With Zero Sealent Left On them. The 4 Spots Were The Exact Spots Where My Wheels Are When I Wash Them. If Its Strong Enough To Remove Driveway Sealent, its STrong Enough To Be Careful With.
    IMHO, it's time to lay down the EO. However, withdrawl symptoms may occur.
    JNGR, put the bottle down and slowly back away. It'll be ok. Wait, what are you doing?! Err...Ow...but... give that back! Stop!
    mental image: JNGR running like a maniac down the street, cackling away like a mad man, EO in hand; his baby blue Autopian apron flapping in the breeze.
  5. #5
    FUEL's Avatar
    Join Date
    May 2003
    Location
    Twin Cities, Minnesota
    Posts
    195
    I am sure you thought of this already but I thought Id chime in. I initially did not like Griots wheel cleaner but I love it now. A2Z is great, I used it a lot but I too think it is too strong on my Maximas rims. I use it on neglected clients cars but on my daily driver I have 4 coats of Z on the rims so car wash soao usually gets the dust off other wise just a squirt or three ot Griots does the trick. Just a tip had you not thought about it.
  6. #6
    BradNC's Avatar
    Join Date
    Oct 2002
    Location
    Down by the river, CA
    Posts
    278
    I too loved Griot's (until I sent it back) . I now use Hi-Temps wheel cleaner and love it. Cheap too!
    Brad
    If I ever fall off a cliff, all I need is one of the extension cords from my garage. I guarandamntee you it will catch on something on the way down!
  7. #7
    Jngrbrdman's Avatar
    Join Date
    Jul 2001
    Location
    Posts
    6,219
    Blog Entries
    5
    Images
    18
    Since P21S and Platinum are what I've got then I think I'll use those till they are gone. I've never shopped at Griots, and although I know they have some great products, I've just found what works for me in other places and haven't got around to shopping there. If Platinum and P21S don't do the trick then I'm sure I'll be looking for other options. Until then, this is my new logo. Sorry for the how crude it is. I'm at work and I only have MS Paint to work with.
    Attached Thumbnails Attached Thumbnails A2Z may be causing damage??-dsc00898.jpg
  8. #8
    Join Date
    Jul 2002
    Location
    Indiana
    Posts
    543
    I have a question about wheel cleaners in general. Most on this board are fanatical about cleaning and detailing at least one of their cars. Personally my household has three cars my daily driver/beater that is gets very neglected (except when I am experimenting and don't want to screw the nice cars up) and my wifes daily driver and my garage queen. I have never used wheel cleaner on any of my cars and can pretty much get them spotless with Z7 and a wash mitt and about 2-3 minutes a wheel. This was even before I started applying Z2 to the wheels (PA -- Pre Autopia) and as a reference my wifes car and the garage queen are horrible when it comes to brake dust. Why use the cleaners? The risk just seems too great. Am I missing something or is it a time thing? I can understand those that do detailing for a living because time is money but for the fanatics l don't understand.
    Brian
    2007 Black Cayman S
    2000 Black BMW 328i
  9. #9
    Fr0zen's Avatar
    Join Date
    Apr 2003
    Location
    Chicago,Illinois
    Posts
    586
    I also Dont use any wheel Cleaner. I dont know what the big fuss was about takeing 30min to Get a wheel to factory shape after not being washed months. If I get something really caked Just a little diluted Hi-Intensity Cleaner and its all gone. I usally just clean it with a stiff brush and Dawn.
  10. #10
    C. Charles Hahn's Avatar
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,607
    the biggest reason to use a wheel cleaner is that although the wheel may look clean after using Z7, I guarantee there is still a residual ammount of brake dust/etc. on the wheels or, more likely, the tires. The A2Z is designed (from what I understand) to be a dual purpose wheel and tire cleaner (hence why the old EOTC and black bottle A2Z were phased out.) and makes quick work of removing this buildup.
    Even on cars that are washed weekly such as mine are, if I let the wheel and tire cleaner go for 2-3 washings I can say with certainty that the wheels and tires will give off an almost black residue when I clean/scrub them. This is the primary reason why a cleaner specific to this task is so essential. Especially with the tires, you may not even notice the buildup if you keep the tires dressed but believe me its there.
    Now, I just started using the new formula A2Z a few weeks ago and have to say its alot better than the old stuff (I didn't use that because it just seemed to not do as well as the Meguiar's "Gold Class Wheel Cleaner" I had...) but I do agree its alot stronger than any other wheel cleaner I've used... I used to have a 10-step process for getting the wheels and tires truly clean and spotless, but now with the A2Z I can do it in only one step with the same level of clean for a result.
    I can't speak much for dammage as my wheels were already messed up when I bought my truck from some kind of oxidation with the wheel weights, but I'll keep an eye on it to see if it gets worse. I can also keep an eye on my wife's car because its wheels are mint. It doesn't get washed as often though .
    I'm still trying to trace what made a strange rust-like spot on my driveway, its in the spot I always put my bottles of product when washing, so who knows what it could be?
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  11. #11
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,607
    the problems with this are that EF-HI does as bad/worse things to wheels over time than even Simple Green could potentially do. (Just ask Brad B. and he'll tell you his SG horror story.) Also if you're talking about using a stiff brush on the wheels, don't you worry that it will scratch them? I use a stiff brush for tires but always use something no harder than a soft-bristle toothbrush for the wheels.
  12. #12
    Jngrbrdman's Avatar
    Join Date
    Jul 2001
    Location
    Posts
    6,219
    Blog Entries
    5
    Images
    18
    Cleaning your wheels without using wheel cleaner is like brushing your teeth without using toothpaste. Does the toothpaste really make a difference? I'd say it does. Wheel cleaners are similar. If you properly maintain your wheels then you can clean them with just a wheel brush and soapy water. To get the baked on crud off it may require a little bit of help. I definitely think that there is a place for wheel cleaners in our work. If you keep your wheels in good shape with Klasse or Zaino or whatever then there probably isn't as much of a need for a good wheel cleaner, but for the wheels that aren't treated already I don't know how I would get along without it. Time is money when you are detailing a client's car and you don't want to have to sit there with a toothbrush and some soapy water when a (relatively) safe product like A2Z could be used and save you the effort.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
