Page 1 of 3 123 LastLast
Results 1 to 12 of 36
Like Tree5Likes
Thread: Opti-coat application problem
  1. #1
    Join Date
    Sep 2002
    Location
    SoCal
    Posts
    301
    I've search for anyone that has had this problem that I have had after applying OC. It seems from all the reading and watching some videos that if I follow the procedure religiously, I should get great results. I guess this product has gotten the better of me. I noticed after applying OC and waiting 3- 5 min. to wipe off with a clean microfiber towel that I was getting some milky splotchy patches that has taken some elbow grease to get rid of. It has not been too warm here in SoCal, normal, 75°, all done in my garage.
  2. #2
    Re: Opti-coat application problem
    chrisguga's Avatar
    Join Date
    Aug 2011
    Posts
    323
    I personally don't leave it on quite that long before buffing with a microfiber.
    Also, I noticed what looked like slight marring/holograms after I applied it, but within 24 hours they went away.
  3. #3
    WCD
    WCD is offline
    WCD's Avatar
    Join Date
    Dec 2003
    Location
    California
    Posts
    1,135
    Too much product and what are you using for an applicator? A cut 2" mf towel can work very well. Sound like high and low spots.
    I do not have too much experience, but this is my thought.
    Robert and Susan Regan
    Towel Pros Microfiber
  4. #4
    C. Charles Hahn's Avatar
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,610
    What sort of surface prep did you do prior to application?
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  5. #5
    Dan
    Dan is offline
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,898
    Applying and waiting to wipe off??? You apply and wait. If you see high spots, you can work those out a bit. I know this sounds silly, but are you following the directions?
  6. #6
    Join Date
    Sep 2002
    Location
    SoCal
    Posts
    301
    First I went over the vehicle with M205 then I applied a liberal spray of IPA which did dry pretty quickly as I was wiping up with microfiber towel. The applicator is the one that came with the product. So how long do you leave OC on the vehicle before wiping down? i would do 1/2 of the hood (G35) with OC before I would wipe it off.
  7. #7
    chrisguga's Avatar
    Join Date
    Aug 2011
    Posts
    323
    I personally do no more than half of a hood before leveling.
    I apply 7-8 drops to the applicator, do as large of an area I can going side to side and up and down, apply 7-8 more drops, same thing to the next area, and then immediately start at the first area leveling it with my microfiber and I continue to wipe both areas for a few minutes to make darn sure it's nice and evenly distributed and all the excess is wiped off.
    This technique worked well for me. It sounds like you're letting it sit for too long before leveling it.
  8. #8
    Dan
    Dan is offline
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,898
    Perhaps my approach is different, but I apply it just like Optiseal, the aim is to have no high spots. I put it on thin enough to feel it going on, it's hard to see at times, especially on lighter colors. Then IF I see high spots, I'll go back and level with the APPLICATOR.
    If I'm reading the OP's post correctly, he is applying thick, then wiping off and still getting high spots.
  9. #9
    Join Date
    Sep 2002
    Location
    SoCal
    Posts
    301
    Perhaps you are right, I'm not sure. I know as I am applying it, as in the hood, that the applicator will jump out of my hand from grabbing onto the paint and not sliding, so I have to apply more and then it will move a bit more easier. I think I am applying about 8 - 10 drops, and when the applicator won't slide I feel I need to add more drops.
  10. #10
    Dan
    Dan is offline
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,898
    Yeah, there is definitely a fine line between the applicator grabbing and sliding easily. The key is, if you get lots of high spots, you are using too much. I think 1-3 high spots per panel is ok, but anymore than that, you are using too much. Wait 5 minutes and if you see high spots, level them with the applicator.
    FWIW, I'm getting about 3 complete cars out of a syringe.
  11. #11
    RaskyR1's Avatar
    Join Date
    Jan 2009
    Location
    Shakopee, MN
    Posts
    2,927
    I don't wait to level off high spots and I've never agreed with that recommendation, however I'm using Opti-Guard and OC 2.0 may be more forgiving, but even then I don't wait.
    My guess is that some of the oils were still remaining behind from the M205 (cloudy look). I strongly suggest washing the car after polishing with CGCW and some Power Clean, especially if you are not using Optimum polishes (I usually wash even if I am). Follow that up with an Eraser or IPA wipe down. Also be sure that you use a clean side of the towel for each section you wipe down, otherwise you are just transferring the oils to the next panel. I end up using about 4 towels to do a wipe down.
    You should be able to hit those spots after it's cured with some Poli-Seal to level them out, either by hand or on the DA with a finishing pad and speed of 3-4.
    Hope this helps,
    Rasky
  12. #12
    Dan
    Dan is offline
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,898
    Rasky makes some good points about proper prep!
  1. After paint correction - opti-seal or opti-coat + other ?'s
    By LeMarque in forum Machine Polishing & Sanding
    Last Post: 05-30-12, 09:31
  2. FS: Optimum Opti-Coat 1.0 (Opti-Guard), AQuartz,
    By GatorJ in forum Good Deals
    Last Post: 05-22-12, 02:04
  3. Replies: 4
    Last Post: 04-19-12, 06:15
  4. Results/Thoughts: Applying Opti-Seal/Opti-Coat with an Air Brush
    By SuperBee364 in forum Car Detailing Product Discussion
    Last Post: 12-08-11, 07:32
  5. ***My Methods For Opti-Coat Application***
    By Anthony Orosco in forum Car Detailing Product Discussion
    Last Post: 10-04-11, 02:00
Posting Permissions
  • You may not post replies
  • You may not edit your posts
