Originally Posted by Spike73
I have a 1999 camry xle and the driver's side seat is pretty hard and cracked. Is there any product I can use to recondition the leather? I was thinking of trying Zaino Z-9 and Z-10.
These are the guides to “Recondition Old Cracked Leather Seats”:
A. Prep Cleaning:
1. Prep clean with a pH 7.7 Strong Prep Cleaner.
2. Clean with a pH 3.8 all purpose leather-safe cleaner.
3. Acidifier rinse with a pH 3.0 rinse.
B. Leather Rejuvenation:
4. Hydrate with a pH 3.3 leather hydrator
5. Fatliquor with a pH 5.0 fatliquor – leather rejuvenator.
6. Hydrogen-bond strengthening with above #3 to drive the fatliquor into the leather structure with a squeaky clean surface.
C. Leather Strengthening - Weak, Worn and Cracks:
7. Strengthen by saturating the weak and crack areas with a leather impregnator.
D. Bonding and Filling Gaps of Cracks:
8. A leather stucco or leather bond is used, could by intermixed to give best result of bonding and flexibility to reduce future cracks.
E. Adhesion Promoter:
9. An adhesion promoter ensures that the color coats have sufficient anchorage to prevent delaminating or peeling.
F. High Performance Color Coating:
10. High performance pigments are designed against UV fading for outdoors especially for autos.
G. Auto Topcoats:
11. These are the toughest urethane topcoats used especially for auto leather seats.
H. Non-Stick Protector:
12. To increase leather resistance against wet and dry rubs, thus reduce scuff and abrasion.
And it’s to reduce friction squeaks when leather rubs against leather during movement.
To impart a non-stick breathable barrier essentially to shield the detrimental effects of sticky soiling including the nasty ballpoint ink.
And it does helps to remove those tenacious dye-transfers especially on light colored leathers easily without resorting to unnecessary color refinishing.
And it’s to enhance the leather with a soft natural buttery-feel with a classic leather scent that charms.
There is no short-cut to a successful restoration.
It’s all hard work that will bring you magical results that last for practical enjoyment with pride.
Roger Koh
Leather Doctor®
