Old 11-03-09, 07:56   #1 (permalink)
maxshine is offline
Ultima Paint Guard - gone bad ?
I bought the sample kit a couple years ago and decided to try it (being using Optimum Spray). Upon opening box, etc. I noticed what appeared to be a 'hardened line' of product that had formed inside the bottle where it had been lying on its side. (I scraped it with a toothpick)
Is the product still worth using ?
I searched the other day and thought I found posts discussing 'particles' in the solution but I can't find them now.
thanks
02 Maxima SE
AIO, SG, UPP, PS
Old 11-03-09, 08:19   #2 (permalink)
wannafbody is offline
Re: Ultima Paint Guard - gone bad ?
Ultima has a history of the product jelling in the bottle. The only way to know for sure if it's still good is to try it. I suspect that some of the polymer has activated so it probably won't be as durable but still should work.
2000 WS6 TA NBM
Old 11-03-09, 08:41   #3 (permalink)
MrRumble is offline
Same thing happened to my sample kit. I first used a popsicle stick to loosen it up, then mixed it (very) vigorously until it all mixed up again. If you let it sit for a period of time, I find it'll happen again. *Edit, I realize I didn't answer your question. Scientifically, I don't know if it's become much less effective, but I use it anyway, and it still seems to sheet water and add slickness and shine.
Old 11-04-09, 05:01   #4 (permalink)
Rob22315's Avatar
Rob22315 is offline
My bottle is at least a year and a half old and I haven't had problems with clouding or gelling. Two things I do which may help - always make sure the bottle is sealed before storing and don't leave it in a cold place during the winter.
I still have the original trigger sprayer with the little blue cap. I try to put a small vacuum into the bottle before putting the cap on the sprayer to reduce oxygen getting into the bottle. I suppose the ultimate storage solution would be to deaden the atmosphere in the bottle with nitrogen.
I move most of my detailing supplies into the utility area around my basement heater. Sub-freezing temps play havoc with many of the chemicals in our detailing supplies and tends to make components - especially in water/hydrocarbon mixes - separate so I don't leave my stuff in the garage over winter. My guess is the extra heat around the heater keeps the chemicals from gumming up. This is a little counter to accepted knowledge about chemical reactions where heat usually speeds them up.
I can only say this is what I do and I haven't had problems yet. I can't promise you similar results because of sound theory. Note my bottle of UPGP is 2/3's full because I only have two cars which I reseal every 2 or 3 months.
It's hard to recover when you're the disease
Old 11-04-09, 06:58   #5 (permalink)
maxshine is offline
I tried what MrRumble did but the particles did not mix back in the solution. So I let them settle and poured the contents(minus particles) to a new bottle, cleaned original bottle, poured back in original bottle and will apply a coat today. If it doesn't seem to apply, cure, etc. properly I'll just toss it. I'm happy with OS.
FYI - the botlle had never been opened - still in wrap, always kept in house. For all I know ity shipped that way. If the product needs continual attention - shaking, etc. This should have been noted in package description.
02 Maxima SE
AIO, SG, UPP, PS
Old 11-06-09, 11:44   #6 (permalink)
bcwang is offline
I find it strange that some people have absolutely no problems with this while others have this happen in sealed new bottles stored at room temperature.
Old 11-07-09, 02:56   #7 (permalink)
Danforz is offline
Maybe Dave could chime in on this?
Old 11-07-09, 06:28   #8 (permalink)
maxshine is offline
I applied one coat and it seemed OK. It seems a bit more 'oily' than OS and dried slower. It also seemed to collect more dust.
02 Maxima SE
AIO, SG, UPP, PS
Save time, effort, and your vehicle's paint with Ultima Paint Guard Plus. Meghan@Autogeek Product Spotlights 0 06-03-09 10:02
Paint Clinic DavidB Guide to Detailing 0 11-10-06 02:10
Using the Porter Cable 7424 Car Polisher DavidB Guide to Detailing 0 11-10-06 02:09
Over Polishing Paint DavidB Guide to Detailing 0 11-10-06 02:09
