06-10-09, 01:58
DWG/UPGP/DWG
Dsoto87 is offline
Optimum Power Clean Worth It?
So lately for wheels, tires, wheel wells, and engines I've been using Amazing Roll Off. I have no complaints about this product and love using it.
I've been looking for a product that has a few more uses though and a little bit easier on the wallet (I've only diluted ARO 1:1 at the most). ARO also can't be used on interiors if need be. Basically I'm just looking for a good APC.
According to the label megs APC+ can be pretty heavily diluted and still be effective. Its also pretty cheap for a gallon. On the other hand you have OPC which can't be diluted any where near as far and is essentially more than double the cost.
The reason I'm considering OPC is because I'm a huge fan of all their other products. OPC and the car wash are the only 2 products I don't have. I've felt all their other products are priced extremely competively and perform at a higher price point. This is the only product I've been on the fence about.
I would just like to know what seperates OPC from other APCs. Is it worth the extra cost? Are megs dilution ratios inflated, or are Optimums underrated? Any help would be appreciated.
06-10-09, 02:56
@hotmail.com
integritydetail is offline
Re: Optimum Power Clean Worth It?
IMO, it should not replace your old APC, but compliment it. It should be used on "special" surfaces where safety is an issue. Leather, nav screens, plastics, etc that are sometimes damaged by APC.
Optimum Results demand Optimum Products*
*Great results can be achieved with any high end line. I use and recommend Optimum.
06-10-09, 07:38
RustyBumper is offline
OPC is a pretty cool product. I've seen it used to clean a wide variety of things from pedals to leather seats. When used in conjunction with steam, OPC leaves whatever it is you're cleaning looking new.
06-10-09, 08:19
willtothewong is offline
i too am looking into purchasing OPC and wondering if it was worth it
i will most likely get the gallon size to get the best bang for the buck
06-11-09, 07:03
U Bring It - I Bling It
David Fermani is offline
Now I'm confused? Why can't it all together replace it? Can't it do just as much as a normal APC, but even more? If not, please explain......
Originally Posted by GoudyL
06-11-09, 08:15
DWG/UPGP/DWG
Dsoto87 is offline
Yea I didnt get that either David. So is it basically a more gentle apc? What would be the difference between using OPC and a different APC but at a high dilution rate?
06-11-09, 08:23
Calm like a Bomb
EisenHulk is offline
I'm going to eventually try OPC, but for the money, it's tough to beat Megs APC and/or APC+.
06-11-09, 09:02
lamby is offline
I'm guessing he means its expensive, so use it where another apc wouldn't work, like saying don't use di water to water your lawn I guess
06-11-09, 10:48
DWG/UPGP/DWG
Dsoto87 is offline
So is it more concentrated? What I'm saying is, will this stuff clean up what another apc can't even at a low dilution ration 1:3 etc.
I saw scottwaxes post about opc cleaning up some paint splatter but I wonder if any apc would have done the job.
Anyways I bought a gallon of Megs APC+. I still would like to hear some opinions on OPC though as I'm still interested
06-11-09, 10:50
DWG/UPGP/DWG
Dsoto87 is offline
I can't edit my posts for some reason so ill just say this simply, does OPC do anything that any other apc can't?
You don't water your lawn with DI water because it won't perform its duties in that situation any better than tap water. That's just a waste. So will opc perform certain taks better than an apc?
06-12-09, 11:37
@hotmail.com
I've had other APC's do damage that OPC didn't on the same panel, so the question is not what it does, but what is doesn't do. (jack up trim, and on some surfaces like tires it will get a ton off after you already did APC)
06-13-09, 12:04
ToadWart is offline
anyone have the msds or know the health rating of opc
