09-05-09, 10:27
#37 (permalink)
MDRX8 is offline
Re: Interesting quote on Meguiars new 205
I can't see it would be better than PO85RD or 106FF
*****ZOOM-ZOOM FOREVER*****
09-05-09, 10:44
#38 (permalink)
formerly iamwaxman
Kevin Brown is offline
Great feedback!
May I make a recommendation for final finishing with M205 via random orbital?
Lots of super-experienced guys here so I do not wish to come across as a know-it-all, because I certainly do not!
This is what works best for me:
PREP:
• For final finishing with M205, use a fresh pad. Prime the pad thoroughly by rubbing M205 in with your hand. Make sure there are no dry spots on the pad face.
• Let it sit for a few minutes- this will allow the liquid to permeate the foam.
• Before using, press the pad face into a microfiber towel, use a slow speed setting, and turn the machine on. Let it run for 5-10 seconds while you work the towel against the pad. this will remove most of the "loose" abrasive grains, while applying a very thin coating to the foam structure.
• Apply five or six small dots of M205 to the pad.
POLISH:
• Apply using FIRM or SOLID pressure, use a speed setting in the low range. Ideally, the machine should be able to spin the pad a small degree- any amount will do. The goal is to keep the pad from "flat-spotting". We are not looking for speed- we just want slow and consistent movement of the pad. If the pad is spinning anything amount over 2-3 times per second, slow the speed setting even more. This is generalized because I have no idea which pad type or size you will be using, nor do I know how it will work on the paint type you are polishing.
•*Do NOT lift up on the pressure near the end of your cycle.
• Do NOT do lots of passes- too much use during an application cycle could load the abrasive material and pad with abraded paint residue, which can then cause micro-marring.
• If at all possible, use compressed air to blast the pad face clean before applying more M205.
• If marring persists, try a test spot by hand to ensure M205 is not marring the surface (use a microfiber applicator pad, microfiber towel, or foam applicator pad to apply. If there is no marring present, then perhaps a different polishing will work better.
Other than that, there will likely be times that M205 will not work as well as another product, but this should be a very rare occurrence. It has no built-in super-durable fillers like Ultrafina, so what you see is what you get.
Before it starts... that is NOT a stab against Ultrafina!
09-05-09, 01:49
#39 (permalink)
Chicagoareanew is offline
What do you think about using 205 with a foam/wool combo pad? Is that acceptable or pushing the limits where 105 with foam would be better?
09-05-09, 02:02
#40 (permalink)
I wouldn't to more aggressive than orange light cut foam with M205. It's a *finishing* polish after all. I wouldn't have even thought to use it with the orange had ebpcivicsi not recommended it, previously I only went as aggressive as the *Griot's* orange foam.
09-05-09, 02:34
#41 (permalink)
Picus is offline
It isn't, but it isn't supposed to be, imo. They are different, and I use them all in different situations. In my experience, 205 has much more cut than 106ff/rd/fpi/fpii, etc... that means it's perfect after 105. The menz finishing polishes are generally useless right after 105 because they don't have the cut to remove 105 marring. So basically I approach it like this.
If I am am using 105, most of the time I will follow with 205. In a lot of cases at that point I am done, which is awesome because it saves me a lot of time. If the paint is soft or I want to jewel the paint I will use a menz polish after 205. Another example - I just one-stepped an a4 with light marring and hard paint with 205. I rarely do one steps but with 205 I can; with 105 I can't because it doesn't finish clean enough and with the menz finishing polishes I can't because they have virtually no cut.
So ya, different uses on different paints.
GTA In Detail
09-05-09, 02:51
#42 (permalink)
scholar is offline
question, has anyone tried 205 after menz SIP?
sorry if this question doesn't make sense to anyone.
thanks
09-05-09, 03:02
#43 (permalink)
U Bring It - I Bling It
David Fermani is offline
Originally Posted by Kevin Brown
I've played around with 205 via PCXP on the last 3 cars I've done (after prior product correction) and every time I've compared it to Menzerna 85RD on adjacent panels, the Menzerna looked noticeably better.
Kevin - Have you ever tried any Menzerna products? I'd be interested to know what you thought in comparison if so.
Originally Posted by GoudyL
09-05-09, 04:01
#44 (permalink)
formerly iamwaxman
I have, but very limited, so I cannot give a fair comparison.
This is the reason I never give advice on Menzerna (or other products that I do not have a lot of experience with).
I have a couple dispenser bottles of Menzerna given to me by PorscheGuy997 that I need to break in to.
As it stands, I have a great opportunity to do some "blind testing" next week.
So I certainly will! Pics, too if I get the chance!
I will see if I have the 85rd and take it along. Is that the only one you recommend I try?
09-05-09, 04:57
#45 (permalink)
Super Intensive Polish & 106 FF/FA will be worth trying too. Expect long work times
09-05-09, 06:01
#46 (permalink)
Cleaning Fool is offline
Fantastic combo. My go to as of late.
09-05-09, 06:23
#47 (permalink)
Got_Leather is offline
The only time I use 85rd is if the paint is already corrected and I'm interested in achieving the extra gloss. "MOST" of the time I can go from M105 to 106FA via white pad and finish down with great results. If not, I'll use Menz 203 Power Finish after M105 and then finish with 85rd.
DJ Mayo
Reflections Detailing
Paint Correction Specialist
09-05-09, 06:43
#48 (permalink)
formerly iamwaxman
I have in my possession PO83 and PO106FA.
I will see if my cohort has some 85RD, then SIP, then 106FF/FA.
