11-20-08, 06:22
#25 (permalink)
Cleaning Fool is offline
Re: I think I'm becoming an OPTIMUM convert!
I like adding ONR to my regular wash as it softens the water, plus ONR is excellent as a clay bar lube. Big fan of Opti-Seal too. OCW is next on my shopping list.
11-20-08, 10:41
#26 (permalink)
Dreamer
Bigpikle is offline
another fan here
ONR - just really getting into it
OS - amazing ease of use and great look and durability
OCW v2 - easy with a great look as well
OID will be my next QD once I use up all my other bits
Your past is not your potential....
11-21-08, 02:43
#27 (permalink)
MDRX8 is offline
Take OID and place 1 to 2 oz in a spray bottle. Place in frig. Then use as a wax remover. Wax your entire car. Then Oid lets you pain stakingly remove the wax and adds to the gloss and depth of the wax. Frezzing the OID mixture is even better. Creates a spit shine finish !!!!!!
*****ZOOM-ZOOM FOREVER*****
11-21-08, 07:18
#28 (permalink)
dervdave is offline
Yep another Optimum fan here as well, they do all I need to keep my vehicles looking the way I want with the minimum of effort.
I wish I`d found `em sooner.
Ultima is great as well but are missing ONR and OCW type products in their range.
11-21-08, 07:41
#29 (permalink)
Inzane is offline
I don't get it...? Putting OID, a wax safe quick detailer, in the fridge makes it suddenly wax UN-friendly?
How does THAT work?
Jason
09 BMW 335i sedan - Space Grey - daily driver
05 Nissan Altima 3.5SE - Majestic Blue - wife's car
93 Nissan 300ZX TT - Onyx (Black)
11-21-08, 09:26
#30 (permalink)
porta is offline
How does THAT work?
You use cold OID to remove the cured wax
11-21-08, 09:40
#31 (permalink)
Inzane is offline
Oh, I get it now. You meant remove as in buffing off a wax. For some reason I got mixed up and thought you meant stripping wax off the car. My bad.
Jason
11-21-08, 09:43
#32 (permalink)
dallen is offline
Currently i have all their Polish and Compound and ONR, I am planning on by all of their product to replace the products i use on costumer car. They are cheap and good can beat that.
11-21-08, 09:57
#33 (permalink)
Newjack McZillion Q's
thesacrifice is offline
Originally Posted by dublifecrisis
Opti-seal-2 squirts on a fresh foam pad to prime it and then 1 squirt per panel. any remaining streaks after 3-5 minutes can be quickly blotted off with a clean MF. A bottle will probably do at least 100 applications.
Try a microfiber towel for application. Kiss streaking goodbye
The only complaint I have about Optimum (other then their polish work times) is that Poliseal can gum up and if you miss whiping off a spot, it takes some real elbow grease to remove it at a later time.
me: Seafoam? what's that gf: I bet it's something new and cool and you're going to want it! me: why do you say that?
gf: cause you want everything
11-22-08, 04:20
#34 (permalink)
Waxophile Autojourno
Bence is offline
Definitely too much product. With the proper amounts, OPS doesn't even leave a trace behind itself.
11-22-08, 11:00
#35 (permalink)
Prep Prep Prep!
SilvaBimma is offline
Originally Posted by reparebrise
Fergnation
If you had problems with optimum polishes you must tell us what pads you used with them. Some pads react quite badly with them, also they work very differntly than other compounds(less is more) To polish a average mid size sedan takes less than 1oz of product, use more and you will be cusring for sure.
As for mixing ratios for OID I mix 3to 1 as requested, but with distlled water. If you are a very hot climate, or working in the sun add 10% rubbing alcohol, makes the product less streaky on a hot car.
Do Lake Country or Meguiars pads work better? Heard the American Buffing pads are better suited.
11-22-08, 11:18
#36 (permalink)
Fallguy is offline
When applying PS should I use a pol. pad or fin.pad on with my PC ?
What speed ? This is a AIO correct ?
2006 Toyota 4 runner 4x4 Sport V8 Galatic Gray
2004 Ford Escape black 4x4
2003 Mustang Cobra convt. Silver/Black top 427 RWHP
