Old 05-18-08, 08:18   #1 (permalink)
StealthMode's Avatar
StealthMode is offline
I need something to dress my door seals with
My door seals are the source of a lot of rattles/squeaks on my 02 VW Jetta. What can I use to lube these that doesn't dry up after a day? I usually use 303 with good results, but yea, after a day or two it's back... Not sure I want to soak them with WD-40 or something smelly Would Black Wow be good for this?
On a second note, is there any adhesive felt tape that would stick well to door seals that I could use? I am really at a loss as to what to do about this. Of course now this might be under the wrong sub-forum now.. Anyway, thanks for any suggestions.
Old 05-18-08, 08:54   #2 (permalink)
Paint time machine
shine's Avatar
shine is offline
Re: I need something to dress my door seals with
1Z einszett Gummi Pflege might be worth a try. I haven't used it much so I can't say how long it lasts.
Old 05-19-08, 06:38   #3 (permalink)
abbeysdad is offline
I've never really heard of door squeaks because of gasket dressing - dressing just keep gaskets new longer. Are you sure you don't need to have the door alignment checked?
Old 05-19-08, 08:59   #4 (permalink)
No, the seals aren't squeaking because of dressing, I need a dressing that lasts awhile so the seals are lubed so to speak so they don't squeak. It's a common problem with VW's and 5 Series BMW's. Over time the seals dry out and cause a sound that is similar to a rattle or squeak. My door is aligned and my hinges are tight.
Old 05-19-08, 09:25   #5 (permalink)
Street Rodder
Eliot Ness's Avatar
Eliot Ness is offline
+ 1 on the Gummi Pflege. It seems to work pretty well when I have used it. The wife used to have a car door that would freeze shut in the winter. One application of the Gummi Pflege about 3 years ago has eliminated that problem.
A similar product that (I think) Accumulator prefers is the Wurth Rubber Care:
Wurth Rubber Care Gel Stick is easy-on rubber care for your seals and weatherstripping.
Both products seem pretty similar with the same style applicator, etc..
John
A.K.A. Eliot Ness
Old 05-19-08, 09:30   #6 (permalink)
Originally Posted by Eliot Ness View Post
+ 1 on the Gummi Pflege. ..A similar product that (I think) Accumulator prefers is the Wurth Rubber Care:
Yeah, side-by-side testing I preferred the Wurth, but both are very good. I don't use the bottle-top foam applicator as it gets soiled in a big/gross way; I put the stuff on a swab/foam/whatever and apply with that.
they call these things "sticks" as if they were like ChapStick but they're really just bottles of liquid with a foam pad on top.
Wurth also makes an aerosol spray called "Rubber Care" that I like, but I'd spray it on an applicator instead of risking overspray-mess. Gotta work fast as the carrier agents evap really quick.
Old 05-19-08, 09:55   #7 (permalink)
member from the old board
tom p.'s Avatar
tom p. is offline
I've got 4 variations of this product: the Wurth spray and stick, the 1Z stick and the ZYMOL "Seal" liquid. I think I prefer the 1Z stick product - - I've had good results with it. However, I was not trying to cure a squeaking issue. You may want to check out the ZYMOL stuff - - it really softens the gasket nicely.
Old 05-19-08, 10:01   #8 (permalink)
Trucculent
NSXTASY's Avatar
NSXTASY is offline
I use FK1 108
Old 05-19-08, 01:16   #9 (permalink)
jedovaty is online now
There's stuff you can get from a chevy dealer called "Krytox", but it is seriously expensive (almost $200 for 9fl oz).
One link provided to me by a friend:
Krytox III - ProwlerOnline, Plymouth/Chrysler Prowler Discussion Forum
Old 05-19-08, 01:21   #10 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is online now
Stoner Trim Shine works on rubber door seals pretty well. Use a piece of cardboard as an over spray shield. Wiping it with an MF afterward helps prevent splotchy looking areas.
Old 05-19-08, 01:23   #11 (permalink)
detailjohn's Avatar
detailjohn is offline
Mark-V's bumper gelle works great.
Old 05-19-08, 01:27   #12 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
save yourself some $ & buy dielectric grease
have use it and spray Silicon lube for years per old GM info
(it is still recommended @ the dealer last time I checked)
food for thought ....I have a 81 Z-28 Camaro that has been outside 24-7 for the 10+ years I have owned it and treating the top-top seals and door seals with dielectric grease & spray Silicon lube
and THEY STILL DO NOT LEAK! if you know anything about these cars that is a feat
also the seals on the conv top of my 97 z-28 camaro are in great shape for 11 years old and spending as much time as possible @ the shore
