Old 05-20-08, 07:54   #25 (permalink)
Omnipotent User
SHICKS's Avatar
SHICKS is offline
Re: I need something to dress my door seals with
Originally Posted by StealthMode View Post
Ironically, it sounds like it is coming from my door lock area, but if I dress the upper seals it goes away until it dries up.
Yea, when the windows are rolled up, they put pressure on the seal causing it to sound like a rattle.
Steve
Old 05-20-08, 09:42   #26 (permalink)
A lot of the products being mentioned sound...uhm..."dirty" to me If not the grease/etc. itself, I'd still worry about dirt-attraction.
BigJimZ28- I for one *do* appreicate how well that stuff must work on your t-tops That *is* very impressive
sal329- Yeah, rumor had it that the BMW gummi stick *was* relabeled 1Z but I dunno for sure. I guess it coulda just as easily been the Wurth stuff, but I bet it was *one* of those.
..How long does the 1z stuff last typically?
Probably not long enough for your situation, which sounds pretty extreme Also, it's probably too "light" a product for this one. Guess my suggestion wasn't very good this time.
Old 05-20-08, 11:57   #27 (permalink)
bpfoley is offline
I have this same exact issue on my 02 Jetta. It drives me absolutely insane. I tried everything from bending the upper door frame with the window down, using all sorts of rubber "moisturizers" and they only last a month or so. I did gain some ground when I completely removed the rain tray moulding that the doors rest against and clean them with Isopropyl alcohol and a MF vigorously. I cleaned off much oxidation and I then let them dry. I worked in Armor All afterward so it was not greasy or slimy to the touch. I am going two months now, but I do still notice some noise in the cold morning commute. In winter the noise drives me batty. I am very close to replacing the rubber moulding and/or taking the car to a body shop for door alignment.
Old 05-20-08, 11:59   #28 (permalink)
mose is offline
I have always used DG TMD and haven't had any problems with it....just my two cents!
Old 05-20-08, 12:14   #29 (permalink)
P.M.S. Adjuster
Jesstzn's Avatar
Jesstzn is offline
GM Makes a silicone emulsion just for that .. bout $5 a bottle .. thats the only thing I found that lasts and works .. its made specifically for that and once applied and rubbed in it also looks good ..
It solved the same issue your having .. I had it on my 03 Passat.
My Web Page & Detailing tips.
Old 05-20-08, 05:00   #30 (permalink)
StealthMode's Avatar
StealthMode is offline
Hmmmm.....I just bought some Syl-Glyde and put it on my upper seal, and what do you know, it didn't go away! I am at my whits end here now... I even smeared some on the edge of the door where I noticed some rubbing, still nothing! So I am off to tear my door panel apart again an hunt this ****er down. Why is it only my passenger front door??? I am thinking after 3 years this is a lost cause.....
Old 05-20-08, 05:01   #31 (permalink)
I might buy some of this just for the hell of it.
Old 05-20-08, 05:38   #32 (permalink)
Found the source of all my pain, it was the freakin door latch!!!!! Apparently it was dried up, so I sprayed some silicone lube/protectant in there and no more creaks, no more rattles, silence! So now that, plus all my other rattle proofing in that door, I should be set! Sorry this turned into a find my rattle issue, but now I have lots of advice on how to keep my door seals nice and fresh. Thanks for the help guys. Just wait, this time tomorrow I will be back complaining that it's still rattling/creaking... Happened 5 times since last week.
Old 05-21-08, 08:57   #33 (permalink)
StealthMode- Well, at least you figured out what it really was. Now we'll see if it stays quiet.
Old 05-21-08, 04:38   #34 (permalink)
Still quiet. I'm thrilled to pieces. Course now I found a little rattle in my center console, but nothing comparable. Anyway, thanks again guys.
Old 05-21-08, 07:08   #35 (permalink)
Lotus Exige S
Rob Tomlin's Avatar
Rob Tomlin is offline
Originally Posted by NSXTASY View Post
I use FK1 108
And for good reason!
AKA "Top Kote".
Old 05-21-08, 07:27   #36 (permalink)
Robb's Avatar
Robb is offline
thats also what i use and have had good success w/ it
