03-05-08, 08:52
RedlineIRL is offline
Pitting with SSR polishes
I remeber seeing more than a few threads on here in the past where people have had trouble with the SSR polishes and a PC combo. Does anyone know what causes it, or if its something that occurs frequently? I was thinking of getting the SSR polishes for the ease of use for beginner polishers, but I do not want to use it if it's hit or miss on the problems that others have had with it.
03-05-08, 08:57
1981 Camaro Z28
BigJimZ28 is offline
Re: Pitting with SSR polishes
I have never had that problem myself(but I do remeber reading the same info as you)
with the SSR's and I used them for several years
but trust me on this you will be much happier with
Danase Swirl Abolishers they are just as easy for the beginer
dust alot less and are only a few dollars more
EDIT: I thought I told you about this before
http://autopia.org/forum/machine-pol...s-7424-a.html?
03-05-08, 09:33
Buff Guy
RAG is offline
I don't think it will cause any "pitting," though you will notice some micromarring via a dual action polisher because the abrasives "gouge" back and forth and don't break down fully.
03-06-08, 11:01
I wonder if it has anything to do with the SSR stuff or is a matter of the paint on the vehicle
I'd never encountered it until I started my (never ending  ) M3 project. I've used H-T EC/rotary and got the "pitting effect" big time in two places: the repainted hood (really, really bad...I'll have to get it repainted) and the front part of the roof (not nearly as bad but still unacceptable). I figure it's a matter of bad repainting ("solvent pop", my painter says that sounds possible) on the hood and weird stone chipping (think about how a bb gun puts a hole in a glass window- small on the side of impact, big on the other side...a conical type of hole) on the roof, but that's just my layman's guess.
03-06-08, 02:50
I'm a shiner
Gears is offline
Has this been a problem with all SSR polishes? I thought it was only happening with SSR 2.5. I've had it happen on original paint.
03-06-08, 06:30
Whoops, I forgot I asked this a while back.
How are the Danase Swirl Abolishers in terms of cut compared to the SSRs? Is the Swirl Abolisher 1 as agressive as the SSR1, and the same for SA2 and SSR2?
Also, would you happen to have any pictures you could post showing the Danase SA results? I'm curious on how it finishes.
That's what I thought also that most cases I've heard of were with 2.5.
Is there really that much of a difference between 2 and 2.5 in terms of cut and the chemical makeup?
I'm curious, when did you notice the pitting Accumulator? Was it after 2.5, 2, or 1?
03-07-08, 09:23
Originally Posted by RedlineIRL
..I'm curious, when did you notice the pitting Accumulator? Was it
after 2.5, 2, or 1?
Sorry, I wasn't clear
I've never used the SSR stuff, I had the "rotary-exposed pitting" after using H-T EC and H-T HC.
That's why I wondered if it had anything to do with the *product* as opposed the the *paint*. IMO in this case I coulda been using any of my other compounds and I still woulda had the same thing once I'd taken off enough clear.
03-07-08, 09:30
Blake is offline
I've used SSR 2.5 and SSR 1 numerous times without any problems and with very good results.
Obviously the finish (paint) you are working on, pad and method can alter your results. I have never had concerns and have used them on several vehicles without a problem.
"If we weren't all crazy..We'd all go insane" Jimmy Buffett
03-07-08, 02:20
No prep, no pride!
a.k.a. Patrick is offline
Ive had it happen on a Porsche with 2.5. I never went back to it........
Owner of Exceldetail.
CA Summers Suck!
03-07-08, 03:23
hockeyplaya13 is offline
I had some pitting after using them on my truck. I used 2.5 and 1, not sure which on it was that caused it. I've switched to Menz now because they are better overall IMO. And I 'm using a PC, if that makes any difference.
03-07-08, 04:17
1981 Camaro Z28
I think the red car was SA2 &SA1
and the blue was SSA3, SSA2, SSA1
I did a review with more info but it looks like it's gone now
03-09-08, 10:46
Buff Guy
RAG is offline
I've never experience this, but you're probably right on the defective paint issue...I just can't see how a particular polish would be at fault.
