Results 1 to 1 of 1
  1. #1
    Removing Surface Contaminants (tree sap, water spots, and etc) Hyperlinks
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Florida, USA / London, England
    Posts
    5,062
    Blog Entries
    40
    Be cognizant that there are two types of paint contamination, 1.Above and 2. Below surface;
    1. Bituminous Asphalt (tar), Industrial Fallout, Tree resin (sap) and etc) which should be removed with detailer’s clay and / or a chemical paint cleaner and ferrous oxide particles (brake / rail dust) which should be removed with a decontamination product
    2. Sintered ferrous oxide particles (brake / rail dust) penetrate the paint surface and if not removed will act as a conduit to the paint matrix system. Once water and heat (reactivity) is added the corrosion process is started, often showing ‘rust spots’ (blooming) on the paint surface, light colours tend show the necessity of decontamination more that darker colours. I am referring to those small brown ferric oxides (rust spots) that just seem to get larger and larger.
    Surface
    Industrial Fallout [: simply a by- product of manufacturing, traffic, and factory pollution. These airborne particles settle on your paints surface causing contamination.]
    Environmental Stains [: insect stains, bird droppings, tree sap, and acid rain spots are amongst the contaminants detailing clay will remove. [1]
    Sub-surface
    Rail Dust [: ferrous oxide FeO] from the day a new car is shipped its surface is under attack. The railcar its sitting is showered with airborne metal particles from the rails. These ferrous metal particles embed themselves into the paint and will eventually oxidize and form rust corrosion under the clear coat]
    Brake Dust [: sintered ferrous oxide FeO) particles from your own and passing vehicles will also get embedded in your paint.]
    The following articles show various ways of removing commonly encountered surface contaminants:-
    Removing Water Marks (Water Spots)
    Bituminous Asphalt (Road Tar) Removal
    Tree resin (sap) Removal
    Excrement Removal
    Removing rust spots (rust blooms)
    Removing Bug Residue and Carcasses
    Removing Calcified Water Marks
    Removing Concrete
    Removing Dust from a Paint Surface
    Paint Removed by Abrasive polishes
    Removal of Oxidized Paint
    Removal of Acidic / Alkali Wheel Surface Damage
    Removal of Bee Pollen Excrement
    Removal of Paint from Clear Coat
    Removal of Smoke Odours
    Relevent Articles
    1. Nanoskin Surface Prep Towel
    2. Environmental Damage
    3. ValuGard Paint Decontamination System
    [Edit: to add new article hyperlinks]
  1. Help removing surface paint contaminants
    By scottfridrich in forum Car Detailing
    Last Post: 06-09-06, 08:01
  2. Need to get off light water spots and contaminants
    By Pheonix in forum Car Detailing
    Last Post: 09-12-03, 04:12
  3. Replies: 5
    Last Post: 09-10-03, 06:15
  4. Does Clay Completely Remove Surface Contaminants?
    By Intermezzo in forum Car Detailing
    Last Post: 01-21-02, 02:56
Posting Permissions
  • You may not post replies
  • You may not edit your posts
