Go Back   Autopia.org > THE CLUB HOUSE > SPONSOR FORUMS > Autogeek.net
Old 06-17-09, 06:58   #1 (permalink)
PBMA
Meghan@Autogeek's Avatar
Meghan@Autogeek is offline
Contact: Send a message via MSN to Meghan@Autogeek
New Flex Products at Autogeek.net
Please stop by and check out the three new Flex products we have in stock.
We all know Flex quality is superb, now we have three new to add to the line up!
FLEX L3709 4 1/2 Inch Angle Grinder
Grind metals, stone, and concrete with this compact, 800 watt grinder!
The FLEX L3709 4 1/2 Inch Angle Grinder is ideal for precision grinding and cutting. The small, lightweight design is comfortable to use over long periods and the grinder maneuvers in confined areas. The FLEX L3709 4 1/2 Inch Angle Grinder is built for durability, performance, and versatility.
Features:
  • Extensive dust protection for motor and gears
  • Lightweight, ergonomic design, short and versatile
  • Spindle lock
  • Side handgrip
  • Tool-free adjustment of safety guard
  • Includes wrench
Specs:
  • Max disc diameter: 125 mm
  • Speed without load: 11000 rpm
  • Power input: 800 watt
  • Weight: 1.80 kg or 3.9 lbs.
FLEX ALi 10.8 Volt Power Drill with Free Flashlight
The FLEX ALi 10.8 Volt Power Drill includes a LED flashlight!
The lithium-ion battery keeps working until the job is done.
The FLEX ALi 10.8 Volt Power Drill makes detail work easy! Polish headlights, isolated scratches, and tight areas with this ever-ready drill with a lithium-ion battery. Equip the FLEX ALi 10.8 Volt Power Drill with a 3 inch buffing pads or a polishing ball to remove scratches and polish surfaces you can't polish with a larger machine. Never miss a spot!
Features:
  • Exchangeable lithium-ion battery 1,3 Ah
  • No memory effect
  • Integrated LED light
  • 11 torque and 1 drill setting
  • Quick release chuck with quick stop motor
  • Externally exchangeable carbon brushes
  • Small machine with lots of power
  • Anti-slip rubber covered grip, for vibration reduced and tireless working
  • Rapid battery charger (charge time 60 min)
  • Spacious shock resistant carry case with metal clasps
Specs:
  • Battery voltage: 10.8 V
  • Battery capacity: 1.3 Ah
  • Torque max: 38 Nm
  • Torque positions: 12
  • Speed without load: 0-500 rpm
  • Chuck: 0.8-10 mm
  • Weight with battery: 1.10 kg or 2.4 lbs.
FLEX ALi 10.8 S Impact Drill
For tough materials, the FLEX Impact Drill makes drilling easy.
Make hard jobs easier with the FLEX ALi 10.8 S Impact Drill. This powerful, lightweight impact drill speeds up construction jobs with 52 Nm of impact power and a long-lasting lithium ion battery. Variable speeds and a LED light make the FLEX ALi 10.8 S Impact Drill suitable for a variety of jobs around the house and garage.
Features:
  • Exchangeable lithium-ion battery 1.3 Ah
  • No memory effect
  • Ergonomically designed, non-slip, soft grip handle for safe, comfortable working
  • Rotary stop
  • Includes battery pack, battery charger, socket and bit set, and 1 plastic carrying case
Specs:
  • Torque max: 52Nm
  • Speed without load: 0-2300 rpm
  • Idle blows: 0-3000 rpm
  • Tool fixture: 1/4"
  • Weight with battery: 1.20 kg or 2.6 lbs.
New car wax and auto detailing products
Polish years off your vehicle with the FLEX XC3401 XMT Intermediate Swirl Remover Kit Meghan@Autogeek Product Spotlights 0 06-03-09 09:44
303 High Tech Fabric Guard Guest Product Spotlights 0 11-20-06 06:13
The Role Silicone Plays in Car Care Products Mike Phillips Guide to Detailing 0 11-19-06 01:53
NIH resource on products Lynn Car Detailing 2 09-05-03 06:38
#20 provided better protection than Zaino.... suginami Car Detailing Product Discussion 107 07-26-03 02:48
