Lake Country Kompressor 7 inch Foam Pads
The Kompressor Foam Buffing Pads by Lake Country are made to hug your vehicle’s curves better than standard foam pads. The slotted pad face allows each Kompressor pad to conform to the shape of the body panel, thereby providing maximum surface contact. Each pad has a “sweet spot” that holds the polish on the pad longer and prolongs the pad life. Maximize your polishing efforts with Lake Country Kompressor Foam Buffing Pads!
Four Different Pads in the Kompressor line:
Purple Cutting 7 inch Foam Pad – Use the purple foam pad to apply compounds and heavy cut swirl removers. The purple foam removes oxidation, heavy swirls, and most scratches.
White Polishing 7 inch Foam Pad – The white foam is less dense than the purple. Use the white pad with polishes, light swirl removers, and prewax cleansers. The foam removes very light imperfections, including swirls and light oxidation.
Black Finessing 7 inch Foam Pad – The black foam pad is very soft. Use it for wax and paint sealant application. The black foam has no cutting ability. It does a great job of spreading an even coat of paint protection.
Red Finishing 7 inch Foam Pad – The red finessing foam pad is the softest Kompressor pad. The red foam can be used to apply glazes, liquid waxes and sealants. This pad is also ideal for jewelling the paint with an ultra fine polish following the use of a swirl remover.
