09-17-08, 07:27
jason@autogeek is offline
Menzerna Power Finish PO 203 now at Autogeek!
Get two-step results with Menzerna’s all-in-one swirl remover and polish!
Menzerna Power Finish PO 203 one polish designed to produce a fantastic gloss in less time than a two step polish process. Designed for the OEM market, Power Finish delivers a shine like Nano Polish with a cutting ability approaching Super Intensive Polish. Eliminate imperfections and rev up the gloss in just one step!
Menzerna Power Finish PO 203 is made for the OEM market as a quick way to polish out light flaws and amplify the paint’s gloss. It has the cutting ability just a step below Super Intensive. This will remove moderate to mild swirls, water spots, and light scratches. Then Menzerna Power Finish PO 203 does something amazing – it burnishes the paint to an ultra high gloss, like you’d expect from Nano Polish. For busy detailers, Menzerna Power Finish PO 203 saves time and money by doing the work of two products.
Menzerna Power Finish PO 203 at Autogeek
09-17-08, 08:50
Spanish OCD
maesal is offline
Re: Menzerna Power Finish PO 203 now at Autogeek!
It's a great polish. I find that the cut is moreless the same than SIP.
09-17-08, 09:09
bert31 is offline
Does it finish out nicer than SIP? If so, it may be a good product to use to clean up wool enduced compounding haze and then go with something like PO87 or Ultrafina for jeweling.
How does its working time compare to SIP?
What pads have you used it on?
09-17-08, 12:17
Spanish OCD
maesal is offline
It's similar to IP. Yes, it cleans that haze great and you can finish with 85RD, PO87, UF, etc...
I use it sometimes with wool to remove swirls an sometimes with medium pad like Meguiars or Propel polishing pads.
09-17-08, 03:39
onelazydawg is offline
With forum discount and discount pricing this seems like a must try product now
09-17-08, 03:53
TH0001 is offline
IP with filling?
09-17-08, 05:03
Bottom Feeder
wfedwar is offline
There's another thread claiming it has less cut than IP (which is less than SIP) and may still require a follow-up finishing polish. So what is it?
09-24-08, 12:18
AKA Bajapat
holland_patrick is offline
I wish there was more of this stuff as i would be using it to polish out the whole car but here is some befores and afters on the rear corner i did.
first pass..
second
trying to get the right angle
and the pad and product..
I used the edge orange pad and worked it pretty long .. and did it in the sun while the paint was still cool from the shade
I think it worked really really well.
and i want more...
09-29-08, 12:22
aka The Twanksta
PresdntialDtail is offline
So is this a good polish to go to for a 1-step detail? Or like Todd said, does it have fillers?
09-29-08, 10:06
King of Gloss!
rydawg is offline
203 is a lot like IP, but a better finish. The correction it gave was great and the gloss was superb.
It worked excellent on wool too. So far I like it a lot.
Ryan Blanchette
09-29-08, 10:10
King of Gloss!
rydawg is offline
Holland Patrick: Is that a 15 ML test package sample of the 203 in your package?
Ryan Blanchette
09-29-08, 10:34
aka The Twanksta
I may need to check this stuff out. Although I just ordered M105, SIP, and 106FA to add to my collection of IP, 106ff, and 85rd! So, I probably have alot ahead of me to learn still!
