Thread: Paint Leveling with HD UNO
05-28-11, 06:26 #13
Re: Paint Leveling with HD UNO
05-28-11, 07:28 #14
Hmm... well that puts some interesting perspective on it. I used the same buffing cycle I would usually use with something like M105/OHC/SIP and got great results in terms of how it finished down (wasn't dry buffing it or anything) but it acted a bit too "oily" when it came time to buff off -- took a bit of effort to break into it and start removing residue with a MF.
Charlie
Automotive Appearance Specialist - Serving Greater Lansing, Michigan
http://www.cchautoappearance.com/
05-28-11, 08:24 #15
In that case you were using too much UNO. I've done that as well too many times. 3 small dime size UNO on the pad is more than enough product per large panels like a door.
On another note One sample bottle of UNO spread out so well, one needed 1/3 of the amount and polished for ever.
05-28-11, 09:12 #16
Guess I have some more experimenting to do; that was about the amount of product I was using (3-4 dimes on the pad) but perhaps because it was one of the 5" DA MF cutting pads even that was too much product (after the pad was primed, that is).
Haven't tried it on foam yet but I will do so on the jobs I have coming up this week to see if I get different results.
Thanks for the insight!Charlie
05-29-11, 09:43 #17
In general the softer the pad, the less product you want to use. If you polish with a pc, use hard pads like orange or yellow to level paint. Heck, put a 5" wool on the pc and go to town. If overworked, just slow the speed down and go over the area and that will help to wipe the product off without any issues. PS: With wool use less and the first pass should start on a slow speed to cover the area. Once the pad is primed keep it at speed 6. No matter what use use UNO with if finishes down so well. You will see. Let us know how it works for you.
05-29-11, 10:26 #18
Barry Theal- Good write-up
Heh heh, so good that I'm tempted to say "you have too much time on your hands, go wash that Lincoln!"
But seriously, you and the other Uno-fans have me seriously thinking about it now.
So you don't prime the pad as per KMB with this stuff?The most interesting man in all of Autopia Land. (<--I didn't enter that!)
05-29-11, 11:11 #19
Barry,
As the owner of a blue Accord, I found those before pics of the one you worked on horrifying!
but it doesn't surprise me in the least, you made it look like it was never used
For anyone at home who may have to resort to spot sanding with 1200-4000 grit discs, can we use a basic PC and a hook and loop backing plate to get similar results?
How is Uno to wipe off? Does it respond/look well after a IPA wipe and a final inspection?Unsuccessful at converting my neighbors to Autopians
05-29-11, 11:48 #20
- Join Date
- Jan 2011
- Posts
- 63
So can you use HD UNO instead of 105/205? It looks like it took it down real good. Or do you use UNO then POXY?
05-29-11, 03:50 #21
05-29-11, 04:07 #22
05-29-11, 04:40 #23
You can absolutely use a PC with the sanding/finishing discs -- I use the Meguiar's Unigrit discs on mine and the results are no different than you'd get with a pneumatic sander (unless the air DA you use has a 3/32" stroke -- which results in a finer scratch pattern).
I won't speak to how wipe-off is since I've been having some quirky issues with that aspect of the product... but I can say that it does look awesome after an IPA wipe-down.How is Uno to wipe off? Does it respond/look well after a IPA wipe and a final inspection?Charlie
05-29-11, 05:25 #24
Not a detail but installed a leveling kit and 32's on my truck
By SShine in forum Click & BragReplies: 5Last Post: 03-23-08, 01:06 -
Leveling Touch Up
By kompressornsc in forum Car DetailingReplies: 7Last Post: 09-08-04, 10:30 -
Leveling touch-up paint
By VIN in forum Car DetailingReplies: 7Last Post: 05-19-04, 07:27 -
Leveling paint with a PC?
By tguil in forum Car DetailingReplies: 2Last Post: 08-23-03, 12:20 -
Leveling orange peel with rubbing compound?
By tguil in forum Car DetailingReplies: 16Last Post: 08-19-03, 12:03
First
LinkBack URL
About LinkBacks
